Fibre 65 speed dropping
Swanseajack1
Message 13 of 13
I went live with fibre 65 last tuesday, when the line went live I was synced at 64Mbs.  I was getting a load of crc errors but the line stayed connected, in the early morning my line resynced but at 60Mbs, I guess this is DLM kicking in.  Still getting crc errors but no dropped connection.
Since then every time during the night my line resyncs at a lower speed, I'm down to 40Mbs now, below my minimum guaranteed speed of 51Mbs.
Is there a way to reset the DLM, to lose over 20Mbs in a few days is beyond.
I know staff won't be here until tomorrow but just posting ready.
oh and I've run through all the steps in your trouble-shooter.
SJ
The Truth Is Out There
12 REPLIES 12
Message 1 of 13
that download speed sounds better 🙂
Message 2 of 13
Just did as requested and download speed is now around 64Mbs wired.
SJ.
Message 3 of 13
Hi Swanseajack1
I've checked the connection stats and the line is in sync at 69.6mb.
Please can you power down the router for a full 30 minutes and then run a speed test.
Message 4 of 13
Was up late last night, around 1am my line went off but resynced straight away at 69Mbs, the speed has shot up but the download remains around 40Mbs on a speed test.
I'm going to leave it settle down for the next few days.
SJ.
Message 5 of 13
Hi Swanseajack1
I will check the connection stats again tomorrow.
Message 6 of 13
ok thanks.
So far it's been 1 day and 5 hours with not one error listed so I'll keep an eye on it 🙂
SJ.
Message 7 of 13
Hi Swanseajack1
If DLM is going to increase the speed then we should start to see some improvements within the next 48hrs.
DLM will change the profile if the connection remains stable and errors on the line are low.
Message 8 of 13
Thanks for the reply, can you confirm it is 48 hours to slowly increase as I read on another site it takes 9 days before moving to the next level.
Message 9 of 13
Thanks for confirming. Unfortunately we can't reset DLM for a fibre connection as this would have to be completed by Openreach as part of a fault investigation. If the errors now remain low now that the router is connected to the test socket then DLM should hopefully start to increase the sync speed again over the next 48hrs.
Message 10 of 13
The speed drop is due to the fact I was swapping routers are and trying to fix the crc errors, yesterday I just plugged it straight into the test socket, since then had no crc errors in 24 hours, but I cant tell if thats due to being on such a low profile due to DLM or if it was a socket error.
If you could reset the DLM then I could tell, I've ordered a proper vdsl filter plate so I can fit that when it arrives.
And no, the line is clear.
SJ.
Message 11 of 13
Hi Swanseajack1,
I've completed a line test now which hasn't detected a fault, however I can see that the sync speed has dropped and the connection looks unstable. Is there any noise on the voice service? Does the main socket have a test socket?
Fedup8
Message 12 of 13
Good luck! It took me around 7 hours of shouting down the phone, over about 5 weeks, to tech support before they realised I was still on a slower profile.
