Fibre 65 with new router - having to reboot router almost daily
stevebakersemail
Message 6 of 6
Hello community,
I have just switched to Fibre 65 last week (20/02/2021), having had reliable TalkTalk internet on the old "Fast Broadband" package for over 10 years. As I'm now working from home I need a fast reliable connection.
I have also received a new Sagemcom "TalkTalk hub" router - Hardware version: FAST5364 3.00, Software version: SG4K10002816t.
The problem I'm having is that it keeps losing internet connection (even though the LED is solid white and logging onto the router reports that it is connected):
xDSl
Line 1
Status
UP
Connection Time
07h53m49s
Link Status
UP
Standard
VDSL2 (G_993_2_ANNEX_ B)
Line Encoding
DMT
Link Encapsulation
ATM (G_992_3_ANNEX_ K_ATM)
Line 1
Downstream
Upstream
Actual Rate [Kbps]
71778
14496
Maximum Rate [Kbps]
70413
14496
Noise Margin [dB]
3.90
5.90
Attenuation [dB]
16.10
0.00
Power [dBm]
12.50
7.30
After rebooting the router the connection returns - I have had to reboot 4 times in the last week and 2 times today.
Any advice is appreciated - do I have a faulty router?
5 REPLIES 5
Message 1 of 6
Hi Steve
Message 2 of 6
Hi Debbie,
Yes please. I'm confident that will fix my issues.
Many thanks,
Steve
Message 3 of 6
Hi Steve
Apologies for the delay.
I can send a Huawei WIFI hub for testing, would you like me to arrange this?
Message 4 of 6
Thanks @Skynet_TX
Yes the log is full of DNS errors (DNS name resolution failure) at the time I was having issues earlier today.
I'll sit tight for some assistance on Monday.
Thanks for the reply
Skynet_TX
Message 5 of 6
Hi @stevebakersemail,
I've seen several reports of similar issues from other customers, sometimes it seems to be a DNS issue with the router. The staff here will be able to help, and if they did think it was this problem they would be able to arrange a replacement router, maybe one of a different type.
If you can access the logs in the router can you see any indications of DNS errors at the times you have these issues.
The staff here won't be around now until Monday, but they should be able to respond to this post early next week to help.
