Fibre 65
Prusai3
Message 6 of 6
Hi i renewed my contract in January 2021 and have just noticed i pay for fibre 65 but only get around 33 megs download speed when Talk Talk know what speed your line is good for why dont i get a better download speed.
jfb
5 REPLIES 5
Message 1 of 6
Hi Prusai3
Thanks for confirming your details.
The predicted speed range for your line is showing between 28.9 and 26mb, with a guaranteed minimum speed of 23.4mb
Your current speed is within the range for your line.
Message 2 of 6
Hi Prusai3
I've checked the connection stats and I can see that your line is in sync at 36mb.
I'm just sending you a Private Message to confirm some details so I can check/confirm the predicted speed range for your line.
Prusai3
Message 3 of 6
Hi profile has been updated.
jfb
Message 4 of 6
Hi Prusai3
  • Name
  • Telephone number
  • Alternative contact number
martswain
Message 5 of 6
What does your contract or Service Centre show as your minimum guaranteed speed ?
Is your quoted 33 the result of a speed test over WiFi, ethernet or is it the actually downstream line rate as reported by your router ?
What speed do you get with just one device connected and a test over a wired (ethernet) connection ?
