Fibre 65
Arimur70
Message 7 of 7
Looking for some help if possible.
Upgraded to Fibre 65 yesterday but apart from a 20 minute spell this morning I haven’t been able to get any internet connection.
I have a wi fi hub, light flashes orange for a while, orange/white then white but only white for a few seconds before back to flashing orange.
Tried restarts, resets, pulling out cables etc but no luck.
Any help would be very much appreciated.
6 REPLIES 6
Message 1 of 7
Hi Arimur70
I'm so glad to hear this, thanks for letting us know 🙂
Message 2 of 7
Hi Debbie, yes all good thanks.
Thanks also for the speedy response on getting this fixed for me.
Ari
Message 3 of 7
Hi Arimur70
Sorry for the delay.
I can see that Openreach closed this fault on 30/09 advising that the fault has been resolved. Fault was fixed at the cabinet.
Has the connection been working ok since your last post?
Arimur70
Message 4 of 7
Hi Skynet_TX, thanks for the quick repsonse. Yes upgraded from Broadband 35 to Fibre 65. Seems to have potentially sorted itself overnight, was stable this morning at least before I left for work.
I did run the online check and Talk Talk did text me to say there was a fault which they'd be sending an Openreach engineer to fix so hopefully that will get things sorted out 🙂
Message 5 of 7
Hi Arimur70
I can see that this fault has been raised to Openreach to be investigated by a line engineer.
We should receive further updates from Openreach within the next 48hrs.
Skynet_TX
Message 6 of 7
Hi @Arimur70,
Were you with TalkTalk before the upgrade, on a slower package ?. If so were you on a Fibre package (i.e. Fibre 35) or a slower ADSL package ?
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
Also, if you have a landline phone can you check to see if that is working normally (i.e. you have a clear dial tone and no noise on the line). Can you also dial 17070, this will read back the phone number of the line, can you ensure this is the number you expect (i.e. the number displayed in 'My Account').
The TalkTalk staff on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
