on 30-06-2022 09:48 PM
Hi, I just changed to this a couple of days ago. It said I’d receive an email confirmation. This has not arrived.
Also, I assume I’ll need a new router - the Wi-Fi hub black. My current one is the Huawei HG633. When will this arrive and will it be simple self setup job?
Grateful for any advice about this. Am not impressed with the lack of communication from talktalk.
on 14-07-2022 07:07 AM
Hi Chris
That's great, thanks for letting us know 🙂
on 13-07-2022 04:37 PM
Hi Debbie
the router arrived yesterday and is working well. Will post the old one to you. Thanks for your help!
on 11-07-2022 06:57 AM
Morning Chris
Debbie 🙂
on 01-07-2022 12:38 PM
Hi Chris
No problem 🙂 I will also post back on this thread to confirm once I've ordered the router.
I have also sent you a Private Message with a link to a short survey for the Community.
Thanks again.
on 01-07-2022 12:37 PM
That would be perfect
many thanks
on 01-07-2022 12:32 PM
Hi Chris
I will place the router order for you on Monday (11/07) Will this be ok?
on 01-07-2022 12:30 PM
That would be great
on 01-07-2022 12:05 PM
There would be no charge but we would send a router returns bag so that the original router can be returned, would you like to go ahead with this and we can send this for you?
on 01-07-2022 11:42 AM
Hi Debbie
thanks for getting in touch
would there be a charge for that?
on 01-07-2022 10:28 AM
Hi Chris
The HG633 router will work ok but I can send you a new router if you would like me to arrange this?
on 01-07-2022 10:25 AM
hi Michelle
it is saying 76 Mbps
on 01-07-2022 07:37 AM
Can I just confirm, what speeds are you currently seeing if you run a speed test?
on 30-06-2022 10:28 PM
Hi @Speedology,
The HG633 fully supports the speeds that Fibre 65 can offer, so you may well not get a new router automatically. If they do send you a new router then yes, you just connect it up in place of your current one and it should just work.
If your new Fibre 65 service is meant to be live already, are you getting the new speeds you expect ?. If you look in 'My Account' does it show that you are now on the Fibre 65 package.
