Fibre Broadband and Mobile Apps
6 REPLIES 6
AldridgeAndy
Super Duper Contributor
First things first, I'm a bit of a fan of the D-Link 3782 router which has been incredibly stable at both my own and my family home.
However over the last few weeks at both locations across various mobile devices apps have been unable to load. Facebook, Amazon, twitter and eBay to name four from the top of my head can just stall with "waiting" and may after a number of minutes respond or ultimately fail with "no connection to the internet".
The actual connection at both locations is spot-on, web browsers on mobile and desktop devices are fine. It's just mobile apps across a variety of devices that are suffering. Even my work VPN connection is working fine at both locations, it's just purely mobile apps.
I've also checked that all home-safe content settings are turned off.
Any ideas?
OCE_Karl
Hi Andy
I've sent you pm.
OCE_Debbie
Hi AldridgeAndy
How has the connection been since your last post?
AldridgeAndy
I've just made the change as per Karl's recommendation to use Google DNS.
If that improves things then I'll also make the same change at my moms house too.
I'll know more in a day or two once I've had time to test.
OCE_Karl
No Problem 🙂
Let me know if there is any improvement.
AldridgeAndy
@OCE_Karl  early signs this morning after the change is that "normal service has been resumed". Everything is very snappy 🙂
Are there any security risks moving away from TalkTalk's DNS and over to Googles?
If it's pretty much risk free then I'll do the same to my moms and my brothers TalkTalk 3782 routers ( I told you I was a fan of them ).
OCE_Karl
No security risks in using Googles DNS. I've always found that Google update their DNS entries quicker.
