Fibre Broadband constant issues with internet connection
Gilmour70
Message 27 of 27
Hi there,
I've been a talktalk customer for many years, without any real issues, until I decided to upgrade to Fibre Broadband. Since upgrading to Fibre Broadband back in July 18 I have at least 7 Bright Sparks engineers and 5 Open Reach engineers out to resolve my internet issues, although they seem to resolve the issue, at the time of the visit, the problem is only fixed on a temporary basis.
I lose my Internet connection again and yet again, I go through the cycle of reporting the problem with the Talktalk Agents/Managers. In fact I had a Bright Sparks Engineer this Monday, who couldn't resolve the issue, so an appointment was made for an Open Reach Engineer who came out on Tuesday (the next day) who fixed the issue, only for the internet to go down again at 9pm that night.  I then phoned the helpline again, on Wednesday 28th, and they've now arranged for a appointment for another Bright Sparks Engineer to come out on the 5th Dec, only for this forever cycle to begin again.
I feel there is more to this than meets the eye, when the engineer goes to the Fibre Box and starts messing around with the cables, this doesn't resolve the issue.  A further investigation is needed to look at the cable running from the box to the home and this should be checked, to see if this is causing the issue.
Does anybody else have these problems?
Best regards
Stuart Gilmour
Cheers Stuart
26 REPLIES 26
Message 1 of 27
Hi Gilmour70,
Our network team have advised that another engineer visit is going to be required. If you'd like us to go ahead with the engineer visit can you confirm:
Message 2 of 27
I've asked our network team to take a look at this. If you don't hear anything later today can you bump the thread tomorrow and we'll check for updates
Message 3 of 27
It appears to happen when it rains and the phone line seems ok.  It went down again last night and hasn't come back on.
Best regards
Stuart Gilmour
Cheers Stuart
Message 4 of 27
Hi Gilmour70,
I'm sorry for the delay. Is it still only dropping when it rains? Is there any noise on the line/no dial tone when it rains or is it just the broadband connection which is affected?
Message 5 of 27
Hi Debbie, yes the line keeps dropping on my Faster Fibre line.  It dropped about 11am and then reconnected around 1.30pm.  28mps is very slow for a Faster Fibre Line.
Best regards
Stuart Gilmour
Cheers Stuart
Message 6 of 27
Hi Stuart
I've checked your connection stats and your line is now showing in sync at 28.7mb.
Is the connection still dropping?
Message 7 of 27
Hi there, had broadband from early hours this morning and upto about 1pm (34 Mbps).  Then it went again.
Spoke to a advisor last night and was informed that there was an outage on my line and that my line will be upgraded 🤞
Best regards
Stuart Gilmour
Cheers Stuart
Message 8 of 27
Hi Stuart,
Line test is showing that your line is potentially being affected by an incident, unfortunately it doesn't give much more information than this. How has it been so far today?
Message 9 of 27
Hi there,
With the broadband connected to the test socket, my internet dropped on the morning of last Saturday and Sunday (19th/20th Jan), this was after some light rain on the same day.  However, this weekend it dropped from Saturday Afternoon until the early hours of Monday morning (26th to 28th Jan), after a substantial amount of rain.  It appears that everytime it rains I lose connection and after it has stopped raining and dries up I get connected again.  Not looking forward to the next time it rains.
Are you able to resolve this?
Best regards
Stuart Gilmour
Cheers Stuart
Message 10 of 27
@Clohayes94
Please start your own topic if you need help to resolve your problem.
Clohayes94
Message 11 of 27
Hi Michelle I have the same problem I am wondering if you can send me a new router for testing purposes to check if this helps
Chloe hayes
Message 12 of 27
Hi Stuart
Please can you leave the router at the test socket and post back on this thread if the connection drops in this set up?
Message 13 of 27
Hi Michelle,
My router has been connected to the test socket many times, when on the phone to India and when the 8 engineers have visited my house.
Should I leave the router connected to the test socket until it drops?
Cheers Stuart
Cheers Stuart
Message 14 of 27
Hi Gilmour70,
Thanks for confirming this. Have you previously tested the router at the test socket? If the connection is still dropping now that the router is connected at the test socket then please let us know and we'll pass this straight over for further investigation.
Message 15 of 27
Hi Debbie,
Just got in from work and connected the router, via the Microfilter, to the test socket.
The router is connected to the internet, please could you test the connection.
Cheers Stuart Gilmour
Cheers Stuart
Message 16 of 27
Hi Stuart
Would it be possible to connect the router at the test socket to see if the connection remains stable at the test socket?
Message 17 of 27
Hi Debbie,
The router isn't connected to the test socket.  However, the internet connection did come back on this morning, but I still don't have a stable line.
I would appreciate it if you forward this to your network team.
Best regards
Stuart Gilmour
Cheers Stuart
Message 18 of 27
Hi Stuart
The line tests have not detected any faults but I can see a high number of re connections on the line.
Is the router currently connected at the test socket? I can then pass this over to our Network Team for investigation.
Message 19 of 27
Hi Chris/Michelle,
Thanks, I kept using the wi-fi hub at 20mps and there was a local power cut on Wednesday Evening 12th Dec.  When the electric came back on, the speed went upto 40-50 mps.
This was ok until Saturday Afternoon (15th Dec), when it was raining and the internet went off again only for it to come on later on in the evening.  However, the internet has now gone off again this afternoon (16th Dec).
I have now connected the broadband router that you just sent and this is yet to connect to the internet.
I would appreciate it if you escalate this problem, as I upgraded to Fibre in July and I've had nothing but problems, with countless numbers of engineers visiting my house, with them only solving the problem in the short term.
Best regards
Stuart Gilmour
Cheers Stuart
Message 20 of 27
Hi Stuart,
I've ordered you a new router to test with, should be with you within a couple of days but please allow up to 5 working days for delivery
