Fibre Router dropping connection several times a day
Pi55ed_off
Message 14 of 14
I recently transferred to Fibre after being with Talktalk since the Tiscali days.
I did this because I work remotely as an engineer in the construction industry. The software we use requires constant link to the main server as the client and server communicate frequently. This is to facilitate a distributed team approach where multiple members of the team access the design files at the same time (these files can be 300Mb+).
My old basic broadband was too slow now I find the new service much worse as it drops out several times a day and has caused damage to the main files it synchronises with on the remote server. This has already cost hours of rework at a cost of around £250 per hour.
When I restart the router it connects back up and gives a full 60 odd Mb/s but after 10 -15 minutes has dropped to below 10Mb/s. Then after maybe an hour or so will randomly drop the connection and I am back to square 1 having to reboot the router again and getting another 10-15 minutes of uptime before the performance starts to degrade again then drops out all together again.
There has always been some sort of issue with the router as the Talktalk service centre has never been able to identify it.
Please help me resolve this as my clients a re starting to ask questions about this and may in the future require financial reimbursement for the damage and subsequent rework I am having to perform because of the damage being inflicted upon their files when the connection drops out during the synchronisation process which is corrupting the files on their server.
Everything else works, Wifi is fine, Wired network is fine but my internet connection is as stable as an Italian taxi driver trying to get home for the match.
13 REPLIES 13
Message 1 of 14
A returns bag has been ordered.
Message 2 of 14
New router arrived this evening. Connected it and my speeds are up at 50-59 Mbps down and 8-9 up.
Thank you for your help.
No bag was provided for return of the old router.
Please send one if you want me to return it.
Now I will need to change my username!
Message 3 of 14
Message 4 of 14
Thanks Karl.
I'll keep you posted with how I get on.
Message 5 of 14
Router on the way.  Just plug it in and it will be ready to go.
Pi55ed_off
Message 6 of 14
Hi Michelle,
please send the replacement router.
We had all the cabling from the pillar to the house replaced a couple of years ago so hopefully a new router will fix it.
Will it be setup and ready to go so I can just plug it in?
Message 7 of 14
I'm sorry for the delay. Would you like us to send a replacement router for testing purposes to rule this out? We would also send a router returns bag so that one of the routers can be returned.
Message 8 of 14
Hi Michelle,
thank you for getting back to me.
The Talktalk router is currently connected.
It is a EchoLife DG8041W Home Gateway Hardware Version: I.1.01, Software Version: v1.05t
I have not tested it with another router as I don't have a spare one.
The phone line sounds clear.
Message 9 of 14
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault, however I can see re-connections on the line. Is the router currently switched on? Which router is currently connected? (make and model) Is the voice service clear with no noise on the line? Have you ever tested with a different router?
Message 10 of 14
Profile now updated with landline number and name.
Pi55ed_off
Message 11 of 14
Hi Skynet and thank you  for your response. I used the PC on the direct wired connection because it means the issue can only be with the Router. When I transfer files within the LAN by connecting another device via a wired (Cat 6) connection I get amazing transfer speeds, as you would expect from a 1 Gig wired network.
When the broadband connection drops the indicator LED on the router is amber then flashes until it reconnects at which point it is white. When it does reconnect speeds are slow. Sometimes sub 2Mbps.
Message 12 of 14
Please can you add your name and TalkTalk landline number to your Community Profile, we can then look into this further.
Skynet_TX
Message 13 of 14
You mention that wired network is fine, so do you mean that the router is remaining connected to the internet all of the time, and wired devices don't lose their connection, and it is only wireless devices that are dropping speed and randomly losing connection, or do you just mean that your local wired LAN is fine, but wired and wireless devices are dropping internet connection ?
What do the lights do on the router when the connection drops, do they indicate the router has lost connection with the internet ?
