Fibre Router
RayWelshman
Message 24 of 24
Hi my router sync speed has dropped from 40Mbs on 31:05:21 to 30Mbs also I get regular dropouts and have to wait for the router to re-sync, am a retired electronics engineer, so I have changed the line filters for new ones, also tried connecting the router to the test socket via a new filter this made no difference, the phone line comes into the house via a small box, I have a punch-down tool so I remade the connections, then goes to the Openreach master socket via a few cm's of cable
Still no better, I can do no more than this, please help, Ray..
23 REPLIES 23
Message 1 of 24
Hi Ray
That's great, thanks for letting us know 🙂
Message 2 of 24
Hi all, I had to go out for 40mins so I turned the router off, now speed test reports 37Mbps, that did the trick 👍👍👍😊😊 Many thanks and Regards from Ray..
Message 3 of 24
OK, just report back here when you can do this.
Message 4 of 24
Hi Debbie, I need the broadband for the rest of the day, I will power it down later tonight and let you know tomorrow..
Regards, Ray.
Message 5 of 24
Hi Ray
Please can you power down your router for a full 30 minutes and then run another speed test?
Message 6 of 24
Hi, you asked me to let you know if everything is ok, although the router sync speed is solid at 40Mbps, speed test never gets any higher than 26Mbps, before this fault occurred it used to show between 36 - 38Mbps, it look as if is being capped by DLM or something similar..
Best regards, Ray..
Message 7 of 24
Hi Ray
That's great news 🙂
The engineer left the following notes:
 Engineer has resolved the fault located in the overhead network.
Message 8 of 24
Hi Debbie, the router sync speed is back to 40Mbps Download and 8.1Mbps upload..
Many thanks for sorting it out for me..👍👍😂
Best Regards, Ray..
Message 9 of 24
Hi Debbie, as a retired electronics engineer, I can tell you there is definitely no problem inside my property, I live next door to a police station, the cable goes from my bungalow to a pole near the police station, I noticed that a tree in the police station has a branch resting on all the phone lines...
Regards, Ray..
Message 10 of 24
Hi Ray
The line test is now detecting a potential line fault and Openreach have assigned this to be investigated by an engineer externally. No appointment to the property has been arranged as yet.
We should receive further updates from the Openreach line engineer within the next 48-72hrs.
Message 11 of 24
Any time after 10 AM
Message 12 of 24
Hi Ray
Thanks for confirming your details.
Please can you provide your availability for the engineer visit AM and PM? I can then arrange this visit.
Message 13 of 24
Hi Ray
Message 14 of 24
Hi Debbie, I think it is the only option left, As a retired engineer myself, I think the problem is just outside my bungalow, so please go ahead and arrange a visit, I hope they are more competent than the usual ones..
Regards, Ray...
Message 15 of 24
Hi Ray
Apologies for this.
As the line test is still detecting a potential fault then the next step will be to arrange an engineer visit.
Would you like me to arrange this?
Message 16 of 24
Hi, yesterday I received the new router, I connected it to the test socket via yet another filter, nothing has changed, it still says there is a problem in my premises, I can do no more than this...
Regards, Ray..
Message 17 of 24
Message 18 of 24
Ok Debbie, I will try anything and will let you know if it improves, perhaps DLM has altered the profile now, we will see what happens in a few days..
Regards, Ray..
Message 19 of 24
Hi Ray
Message 20 of 24
Hi Michelle, I am willing to try another router, my router has F/W version SG4K10002816t however it is possible there may be a line fault between my bungalow and the pole about 5 Meters away, Openreach have had problems not too long ago, the cable goes underground across the road to a large underground "cabinet" Openreach have had problems with water ingress many times al ready this year..
Regards, Ray..
