Fibre Speed Boost not up to expected speed.
Beanz
Whizz Kid
Message 1 of 84
I recently renewed my contract for another 18 months, this time with the Fibre Speed Boost.
At first there was hardly any increase in speed, so I did what was recommended and powered off the modem/router for at least 30 mins. Since then (5 days ago) the download speed has increased from roughly 38Mbps to about 47Mbs. Not exactly a massive improvement, I think you'll agree.
I was promised a minimum of 54Mbps.
The question is, will the speed improve over time or is there a problem?
By the way, I am using the BT Openreach fibre modem that was installed when I started using fibre back in 2014. Could that be causing the reduced speed?
Thanks for any help.
Regards, Beanz
83 REPLIES 83
Message 41 of 84
Hi Beanz,
Ok, please let us know how the connection/speed compares.
Message 42 of 84
OK, I will keep a close eye on it and report back.
Cheers, Beanz
Message 43 of 84
Beanz... If you are able to replace your Mk2 BT Main Socket with a Mk4 type with cams (no insertion tool needed) then you might well get a 15% speed increase. I can confirm that both a neighbour and myself had speeds go up from 50M to 60M just by replacing the main socket.
Message 44 of 84
@johnhoe  You cannot replace Openreach sockets yourself.
Message 45 of 84
"@johnhoe  You cannot replace Openreach sockets yourself"
I didn't say that I did it myself!
Message 46 of 84
OK, just to clear up that it is not a voluntary option and is charged at a considerable cost unless the existing Openreach socket is found to be faulty at their end.
Message 47 of 84
@ferguson The OP has had his case escalated to BTOR. During a visit from an BTOR engineer One of the ways they might bring the speed up to expected is by replacing the Main socket. True? Yes? Thanks...
Message 48 of 84
Hey, so if the BTOR engineer judges that the master socket needs to be replaced because it is faulty then yes, if you had said that in the first place there wouldn't be an argument, just saying that your initial comment was far from clear. Yes? Thanks ...
Message 49 of 84
Hope it's clear now. I am a BTOR engineer!
Message 50 of 84
Then you should know better.
Message 51 of 84
I do.
Message 52 of 84
No you don't. If you choose to give advice here please make it accurate and clear. Now please leave the TalkTalk team to deal with this.
Message 53 of 84
OK. I won't come on here again. Your attitude is extremely negative and unhelpful.
Why on earth would the OP attempt to do this work himself when he has a BTOR engineer coming out to him?
I have read the thread. I have tried to be helpful and bring the option of replacing the main socket into the discussion so that the OP might realise that is an important consideration.
Message 54 of 84
I repeat, if you had made it clear that this is an option that the OR engineer can look at then it would have been accurate. Instead you simply suggested that "...If you are able to replace your Mk2 BT Main Socket with a Mk4 type..." You then went on to make claims about improvements in performance which are unsupportable.
If you are indeed an OR engineer then it is highly irresponsible of you to prejudge the situation based on a forum post. I would imagine that only the engineer on the ground can make the appropriate decision based in conjunction with what TalkTalk have advised.
Message 55 of 84
Keep calm guys!
Just to make it clear, I do not have a BTOR engineer visit booked at the moment. I have decided to wait for a few days to see if the DLM does anything to improve the speed by itself.
Do you think I'm wasting my time?
I appreciate any help on this.
Beanz🙂
Message 56 of 84
@Beanz  Apologies, I knew that. I just got embroiled with the so-called OR guy talking rubbish. At least you know what to fear if they do turn up. They are not all like that to be fair, but many are given the reports you read on here.
Message 57 of 84
No apologies required. I don't know either of you, so I'm not sure who to believe.
Anyway, back to the line sync speed. Is it worth waiting for DLM or am I wasting my time?
Does anyone have any experience of DLM ramping up the speed? If so, about how long did it take?
Thanks for any info.
Beanz🙂
Message 58 of 84
Hi Beanz,
How are you getting on? Have you noticed any improvement since your last post?
Message 59 of 84
Hi Michelle,
Thanks for getting back to me. I am away from home this week, but have left the router on.
When I looked before I left it was still showing a sync speed of around 45Mbps. Still below the guaranteed minimum.
I'll be back on here next week if nothing has changed.
Regards, Beanz
Message 60 of 84
Hi Beanz
I will check the connection stats again on Friday morning to see if there has been any change in the speed.
