Fibre Speed Boost
larrywilkie
Whizz Kid
Hi Debbie,
Yes this was on a wired connection.
Unfortunately I don't have an alternative router as this one was bought as a replacement.
Would the slightly high pings be enough to make a difference from the 70mbps to the 40 that I am getting?
Larry
larrywilkie
Whizz Kid
My apologies,
I should have said 'Michelle' not Debbie See_no_evil
OCE_Michelle
Hi larrywilkie,
Sorry for the delay. Would you like us to send a replacement router for testing purposes to rule this out?
larrywilkie
Whizz Kid
Hi Michelle,
Yes please, that sounds like a good option.
Many thanks
Larry
OCE_Debbie
Hi Larry
Let us know how the connection/speed compares with this router.
larrywilkie
Whizz Kid
Thanks Debbie,
I'll post results on here once all set up and tested.
Larry
OCE_Debbie
larrywilkie
Whizz Kid
HI Debbie,
I received the new router today and have run several download tests.
Unfortunately the results are worse than previously.
I am getting approx 25mbps with the new router compared to what I was getting before.
The router I have received is the older type, but the one I am currently using is the Wi Fi Hub. Would this make a difference?
Larry
OCE_Michelle
Hi Larry,
Thanks for trying this. Just to confirm, was this speed test also completed wired with no other applications running at the same time? Do you also get the same speed on 2 different devices?
larrywilkie
Whizz Kid
Hi Michelle,
It was wired on desktop PC and wireless on mobile, both were similar.
I’ve now plugged the Wi Fi Hub back in and speed has reverted to 39-40mbps
Larry
OCE_Chris
Hi  larrywilkie,
Thanks for trying that. I can't see any obvious reason why your wired throughput speeds should be so low against sync speed. Do you have another device that your can run wired speed tests on just in case there's some issue with the PC
larrywilkie
Whizz Kid
I have tried disconnecting the internet cable from the PC, and running a speed checker on the Smart TV, which is connected by wire, and the speed came out lower on there than on the PC, so I am at a loss!!
Larry
OCE_Debbie
Hi Larry
I think it may be worth arranging a TalkTalk engineer visit so they can complete some testing.
Would you like me to arrange this?
larrywilkie
Whizz Kid
Hi Debbie,
I have just run a speed test now and it came back at 45mbps, which is the fastest I have seen so far.
I recently signed up to a new router trial, which I believe is starting at the end of January.
Maybe it would be wise to see what comes of that before we proceed any further?
Larry
OCE_Michelle
Hi Larry,
Ok thanks for the update and please let us know how the connection compares with the alternative router.
larrywilkie
Whizz Kid
Hi Michelle,
Just an update on this.
Unfortunately I wasn't selected for the router trial, so I can't do any tests on that.
I have just run a status check on my account and it says that speed to my router is 74mbps, but when I carry out a speed check, my result is 44 mbps, so I'm just wondering if there is anything else you can suggest?
Larry
OCE_Michelle
Hi Larry,
I'm sorry to hear this. Is this still a wired speed test? I've re-read through your thread and I can see that you've tried 2 different routers and also ran wired speed tests with 2 different devices, however the throughput speeds are still low.
I can see that you have previously tried switching the router off for a full 30 minutes and then retested the speed. It may be worth trying this again just to see how the throughput speeds compare now.
Is everything ok with the voice service with no noise on the line? If there is still no improvement then could you run another wired ping and trace route and we can ask our Network Team to take a look.
larrywilkie
Whizz Kid
Hi Michelle,
I have just had the router off for 30 mins, and run a retest, and at the moment it is running slower at 29mbps.
There is no noise on the phone line.
Can you send me the links again for the ping and trace route and I will give that a try.
Larry
OCE_Michelle
Hi Larry,
Thanks for trying this again. I've included the Help Article below.
Run a Ping or Traceroute
larrywilkie
Whizz Kid
Good morning Michelle,
Here are the results:
Pinging google.co.uk [216.58.201.35] with 32 bytes of data:
Reply from 216.58.201.35: bytes=32 time=10ms TTL=54
Ping statistics for 216.58.201.35:
Minimum = 10ms, Maximum = 10ms, Average = 10ms
Tracing route to google.co.uk [216.58.201.35]
over a maximum of 30 hops:
1 2 ms 2 ms 2 ms ttrouter [192.168.1.1]
2 * * * Request timed out.
3 7 ms 7 ms 7 ms host-78-151-230-231.as13285.net [78.151.230.231]
4 7 ms 8 ms 7 ms host-78-151-230-230.as13285.net [78.151.230.230]
5 10 ms 10 ms 10 ms host-78-144-11-49.as13285.net [78.144.11.49]
6 10 ms 11 ms 10 ms host-78-144-4-33.as13285.net [78.144.4.33]
7 * * * Request timed out.
8 10 ms 14 ms 11 ms lhr35s04-in-f35.1e100.net [216.58.201.35]
Trace complete.
Kind regards
Larry
