Fibre Sync Speed Has Dropped
Rich1971
Message 28 of 28
I have noticed that my sync speed has dropped recently.
Download used to be around 54mb but now it's sitting at 47mb and upload was 14 but now its 12.
This as you can imagine has affected my download and upload speeds. I used to get just over 50mb down but now I can only get 42.
It has been like this for a couple of weeks and I have tried shutting down the router for 30 minutes several times but it won't recover. It has been connected for over 6 days solid now but it still isn't picking back up.
What can be done to get my speed back?
Many thanks
Rich
27 REPLIES 27
Message 1 of 28
Rich1971
Message 2 of 28
That's great, thank you!
Message 3 of 28
OK I've ordered another Sagemcom, it should be with you within a couple of working days
Rich1971
Message 4 of 28
47mb vs 44mb for the Huawei one.
Message 5 of 28
Hi Rich1971,
Thanks for the update, could I ask what speed the Sagemcom router was syncing at?
Rich1971
Message 6 of 28
I have managed to isolate a potential source of interference so hoping that will improve things.
However, having sent back the non syncing Sagemcom router the replacement Huawei one syncs even lower.
Is is possible to go back to a Sagemcom one again please as it seems to work much better on my line?
Many thanks
Rich
Message 7 of 28
Hi Rich
As advised, we can arrange an engineer visit but we have to advise/confirm potential engineer charges first.
Rich1971
Message 8 of 28
But they also charge if they are unable to find a fault. In that scenario I'm left with a service that isn't performing as it should and a £65 charge.
This is all wrong.
If I have a degraded service and I have followed your instructions to rule out any potential internal causes then my involvement should cease, and it should be over to you to investigate and resolve.
It's unfair for the customer to be left carrying the can if the cause cannot be traced.
Message 9 of 28
Hi Rich
If the fault is found to be with Openreach maintained equipment then no charges should be applied.
By testing with different routers, cables and filters at the test socket, this will help rule out your own equipment or internal wiring.
Rich1971
Message 10 of 28
I have just read the potential charges that could be incurred, seems I would be liable for a whole lot of scenarios.
The service isn't performing as it was and yet it seems I'm the one who has to potentally foot the bill to investigate why.
I can't say I'm happy about that.
Message 11 of 28
Hi Rich
Would you like me to arrange an Openreach engineer visit?
Rich1971
Message 12 of 28
It's always been about the drop in speed(all in my original post),  the connection has always been solid.
Message 13 of 28
Hi Rich
The line test is clear. Is the connection dropping or is this in regards to the speed?
Rich1971
Message 14 of 28
The router arrived Friday and the connection is even worse with it.
DSL synchronization status:Up
Connection status:Showtime
Upstream line rate (kbit/s):13566
Downstream line rate (kbit/s):44836
Maximum upstream rate (kbit/s):13491
Maximum downstream rate (kbit/s):51868
Upstream noise safety coefficient (dB):5.9
Downstream noise safety coefficient (dB):6.1
Line standard:Vdsl2_ANNEX_B
Upstream line attenuation (dB):5.0
Downstream line attenuation (dB):14.6
Upstream output power (dBm):7.5
Downstream output power (dBm):11.9
DSL up time:
2 days 14 hours 3 minutes 46 seconds
Message 15 of 28
Hi Rich
No problem 🙂
Rich1971
Message 16 of 28
That would be great, thanks.
Message 17 of 28
Hi Rich
Would you like me to send a Huawei WIFI hub for testing to see how the connection compares? (as we can't roll back FW on the Sagemcom hub)
Rich1971
Message 18 of 28
My router is now just flashing amber and I cannot connect to it even with a cable.
Any thoughts?
Rich
Message 19 of 28
It's not possible for us to roll back the firmware. There is currently a campaign running to push out the firmware in batches, and so far we have not seen this behaviour in any router running V130.
Rich1971
Message 20 of 28
I've noticed that the router firmware has been updated recently. It's now SG4K100130.
I'm wondering if this is related to the lower sync speed as nothing else has changed my end and there are no faults being picked up on the line.
Is there any way I can go back to SG4K10002810t to test the theory?
