Fibre broadband dropping out
scottjohnturner
Message 13 of 13
Please could I get help
my WiFi connection drops out at least once every hour
and have to wait for it to come back
i have fibre broadband
tried restarting router etc
12 REPLIES 12
Message 1 of 13
Hi scottjohnturner
Debbie 🙂
Message 2 of 13
That would be great
Message 3 of 13
Yes please
kind regards
Message 4 of 13
That would be great
thanks
Scott
Message 5 of 13
Hi scottjohnturner
I'm sorry for the delay.
Would you like me to send a replacement router for testing?
Message 6 of 13
I have asked one of TalkTalk's support to pick your thread up and investigate it for you when they return on Wednesday.
They aim to respond within 48 hours (Monday - Friday), but if more urgent you can always try the Service Centre. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk have responded to you, otherwise, this will just put you further down the queue.
Message 7 of 13
Yes think my router must be faulty
used Ethernet cable
Message 8 of 13
So I assume that the laptop was via an Ethernet cable?
Message 9 of 13
Talk talk WiFi hub
sagemcom
device version FAST 5364-3.TB
Message 10 of 13
Hi this is my router
scottjohnturner
Message 11 of 13
Hi I have tried connecting laptop directly and still same issue
Message 12 of 13
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
