Fibre broadband has halved
lobs54
Message 3 of 3
Changed to fibre broadband last month all was well for a couple of weeks then noticed I was getting less than half the download speed although upload speed is OK.
Have noticed this complaint is quite common, could you please explain why this is so.
Message 1 of 3
Hi lobs54,
Line test is clear and router is in sync at 40Mbps, have you tried Skynet_TX's suggesting and switched the router off for 30 minutes?
Skynet_TX
Message 2 of 3
Hi @lobs54,
Have you tried switching the router off for over 30 minutes, then when you switch it back on it will start a new 'session' in the street cabinet, this can sometimes help it reconnect at a better speed.
