Fibre connection lost
Ste_Nix14
Message 22 of 22
Could a OCE pick this thread up please.
I have the latest Huawei Hub updated to 1.06t to fix Kernel issue. All be it the hub has been alot more stable since the firmware change it keeps dropping the Internet connection 1 or 2 times a day. There is no real explanation in the log to why, the hub it self remains on and uptime is not lost only DSL.
I have tried a old Sky Q fibre hub which never lost connection over 7 days it was connected?
I've ran a line test which shows no issues and have done the normal troubleshooting with changing cables and test socket etc.
Could I get the Sagemcom version sent out to compare please.
Steve -
Have you tried turning it off and on again!
21 REPLIES 21
Message 1 of 22
Message 2 of 22
Thanks Debbie !
Steve -
Message 3 of 22
Hi Ste
Course you can 🙂
It's now switched off as requested.
Ste_Nix14
Message 4 of 22
Could you check and turn off Optimization for my Sagemcom?
Steve -
Message 5 of 22
Hi ste,
I'm really glad to hear this and thanks for keeping us updated 🙂
Message 6 of 22
Hi hope you've enjoyed your weekend.
Please to report no issues touch wood and speeds are settled at 80/D 20/U so v'happy with that 😊.
Thanks for your support on this!
Steve -
Message 7 of 22
Message 8 of 22
Will do! 😊
Steve -
Message 9 of 22
Hi ste2014
That's great 🙂
If you do experience any further issues then please let us know.
Message 10 of 22
Hub received and set up. Touch wood no issues as seen with last Hub. All running fine and devices playing nicely 🤞
Steve -
Message 11 of 22
Hi ste2014
No problem 🙂
Message 12 of 22
As ever, thank-you! 😊
Steve -
Message 13 of 22
Hi ste2014
The Sagemcom WIFI hub is on its way, please allow 24-48hrs for this to arrive.
Message 14 of 22
Yes Chris, can I get another Sagemcom sent to me please to finally compare results.
Steve -
Chris-TalkTalk
Message 15 of 22
Hi ste2014,
Sorry to hear that the you experienced problems with the Sagemcom, are you back using the Huawei?
Message 16 of 22
I had to send Sagemcom straight back. Was not allowing devices to connect to Internet even though devices were connected to hub correctly including wired. Hub was also very buggy could not navigate the interface.
Steve -
Message 17 of 22
Hi Ste
Message 18 of 22
Hi Debbie,
Router received and set up. I will post back here if I face any issues. Its on a older firmware so dreding it updating incase it has the DNS issue 😬
Steve -
Message 19 of 22
Hi ste2014
No problem 🙂
Message 20 of 22
Thank you Debbie!
Steve -
