Fibre constantly dropping out
JK555
Message 3 of 3
I recently switched to fibre broadband (as an existing talktalk customer) and have had constant problems with the connection. It is now dropping out every couple of minutes making it impossible to work from home. Also since the switch, my landline is dead, despite this still being part of my package.
Message 1 of 3
Hi JK555,
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 2 of 3
Hi @JK555,
If the landline is dead then this may indicate something has not been done correctly when moving your line over to fibre, this could also be having an impact on your broadband signal.
It would be worth going to the Service Centre to ‘Run a live connection test’ on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the landline phone & router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
Then they will hopefully be able to respond to this post within a working day or two.
