on 27-04-2019 11:51 AM
I've been in contact with customer support multiple times since at least the 16th of March and its actually becoming a joke now. Ive had 5 Openreach engineer visits and every time they say nothing is wrong.
My connection is being cut on random midnights at approximately the same time and the speed is either cut to 7.9Mbps or put back to 80Mbps. And it only gets put back when I contact customer support.
The longest is was stable was 10 days. Every other time its lasts between 1 and 3 days.
I have a WiFi Hub Sagemcom FAST5364 router. NTE5c mk4 box. Yes the Grey wire is connected. No I don't have a landline phone. And no I'm not switching the hub off at night.
on 30-04-2019 08:30 AM
Hi spencerr86,
I've ordered the router, should be with you within a couple of days but please allow up to 5 working days for delivery
on 29-04-2019 09:08 PM
Okay its worth a try. When can I expect it?
on 29-04-2019 03:55 PM
Hi spencerr86
It would be worth testing with a different router to rule out any possible equipment issues.
Would you like me to send a replacement router for testing?
29-04-2019 03:42 PM - edited 29-04-2019 03:43 PM
I have not tried another router. Would that be a reason why it disconnects at midnight and my incoming speed goes from 80Mbps to 7.9Mbps.
on 29-04-2019 09:48 AM
Hi spencerr86,
Just to confirm, have you ever tested with a different router? If not then please let us know and we can arrange to send a replacement router for testing purposes to rule this out.
on 28-04-2019 09:37 PM
most likely a Prob at the BT end rather than talk talk. BT have been taken to court several times for throttling back internet speeds of non BT customers who rent the lines through BT.
Its a problem we will all have while talk talk rents the lines from BT.
Ive lost connection a few times in the middle of the night with no wanings about it being disconnected or any work being done due to BT not informing talktalk.
on 27-04-2019 03:58 PM
Alas the forum software has partly corrupted your reply. As you do not use wireless connections, then I can only assume that this is an issue with your router, as it is in sync at 79M.
27-04-2019 03:26 PM - edited 27-04-2019 03:30 PM
My PC is connected via wire
Line 1 |
UP |
00h43m11s |
UP |
VDSL2 (G_993_2_ANNEX_ B) |
DMT |
ATM (G_992_3_ANNEX_ K_ATM) |
Line 1 | |
Downstream | Upstream |
7896 | 3199 |
79762 | 3199 |
0.00 | 6.00 |
12.30 | 0.00 |
9.20 | -0.60 |
Thank you for submitting your speedtest results. This will aid our technicians if you have an issue.
We recorded your speed asDownloadUpload1186 KBits/s | (148.25 KBytes/s) |
2927 KBits/s | (365.875 KBytes/s) |
on 27-04-2019 02:52 PM
When this next happens, please can you capture this information so as I can try & help you?
How do you connect wireless, wired, or a mixture? If a mixture is a wired connection better than wireless?
It is important to see what your line is actually capable of and what your current download speed is.
To help diagnose this issue, please can you log on to your router, by opening a web browser (e.g. Internet Explorer, Mozilla Firefox & Google Chrome etc) and then enter this address in the address bar:-
http://192.168.1.1
enter the credentials:-
username: admin
password: the TalkTalk Wi-Fi hub has its own unique password, which can be found at the top of the label on the rear of the router. It is the one labelled "router" or "admin" password, not the wireless one.
Then go to:-
Dashboard > See internet settings > Manage Advanced settings > TalkTalk Wi-Fi Hub
Click on the General tab then scroll down to the page to the xDSL section & copy & paste them into your reply.
Next can you also go to this speed checker (it is useful to have speed test figures taken at the same time as gathering the router's statistics):-
http://www.supportal-test.co.uk/
Alternatively use:-
https://myaccount.talktalk.co.uk/speed-checker/
Do this on both wireless & wired (if you have wired), but with never more than one device connected at a time.
Please can you paste the results here?
