Fibre guaranteed minimum speed never reached no matter how many times I report it
ainarita
Message 32 of 32
I have been with talktalk about 12 years now, and the last 2 with fibre 67 with a minimum guaranteed speed of 51mb, unfortunately that has not been the case a single day. max speed ever has been around 43mb, I have reported it several times, with no improvement, I have now tried to report it yet again but the service center suggests it is my home setting when in fact I have not changed since last time I did the same check. I now have had enough but my contract doesn't end for another year and leaving would mean to pay a penalty , has anybody had a similar problem or know how to solve it? Also trying to contact them by live chat but finding hard to find the link, they used to have great customer service, not anymore.
Ainara
31 REPLIES 31
Message 21 of 32
No I don't, I had to send back the previous one when I received this new one, but that was a few years ago. Can all this be anything to do with the connection little box just outside the house? It does look very old, and it was there when we moved in 14 years ago. Not sure it has ever been checked. The master socket inside was replaced about 4-5 years ago but not that box.
Ainara
Message 22 of 32
Hi ainarita,
Thanks. I've re-checked the connection stats now and the sync speed hasn't increased. Do you have an alternative router that you can test with?
Message 23 of 32
Hi ainarita
Thank you, we will check the connection stats again on Monday to see if DLM has made any changes to the line profile/speed.
Message 24 of 32
Sure, no problem, thank you
Ainara
Message 25 of 32
Hi ainarita,
Thank you. Would it be possible to keep the router connected at the test socket for a few days as it can take DLM up to 48hrs to start making changes to the speed if the connection remains stable?
Message 26 of 32
It is now plugged in the test socket, await further instructions, thank you
Ainara
Message 27 of 32
Dear Michelle,
I did that on sunday with one of your colleagues over the chat and he said the problem was fixed but nothing has improved, in fact yesterday I recorded speeds as low as 1mbps, today it's slightly better at 39mbps but still nowhere near the minimum guaranteed of 49mbps nor the estimated 51mbps-80mbps that service centre says. I will plug it in the test socket again with the microfilter until I hear from you again. Thank you.
Ainara
Message 28 of 32
Hi ainarita,
Thank you. I've run a test on the line which hasn't detected a fault. Does your master socket have a test socket? If it does then would it be possible to connect the microfilter and router at the test socket so we can see if DLM starts to make any changes to the sync speed please?
Message 29 of 32
Info updated
Ainara
Message 30 of 32
Hi ainarita
  • Name
  • Telephone number
  • Alternative contact number
Gliwmaeden2
Message 31 of 32
Live Chat will show as available after 9am, @ainarita, in a link if you scroll down this page:
https://community.talktalk.co.uk/t5/Articles/Our-update-on-Coronavirus/ta-p/2468300
You can also ring 03451 720046 Monday to Saturday (not Sunday), also after 9am.
Staff will be back on here from Monday to Friday.
If you need help from them, please complete your community forum profile details. Go via your avatar/name; settings; launch profile wizard; make sure you put in your landline phone number and a fallback mobile phone number; click finish to save.
