Fibre keeps dropping out
EJ29768
Message 7 of 7
Since Thursday of last week, my Fibre 35 keeps dropping out. It can be fine for a few hours, then the wifi goes down and all devices lose connection. Restarting the hub does always reinstate the connection, but this is happening several times per day.
Mostly the lights on the hub are green and flashing when the wifi drops out, but this morning the internet light was steady red.
I have tried turning the hub off for 20 minutes, then when the problem persisted I turned it off for over half an hour. It happened again after this. When we upgraded to Fibre 35 a few months ago, we weren't supplied with a new hub.
When I do a speed test, the speed to router is 'good', but the speed to devices is 'poor'. There's never a problem with speed, it's just the drop-outs.
I started a new job last Monday and am working from home full time, so as always the timing of this problem is dreadful!
When we had a similar problem a few years ago, a new hub was supplied and this sorted the problem.
Any help is appreciated!
6 REPLIES 6
Message 1 of 7
All tests are clear but I can see there have been drops.  I've a router on the way to you so we can see if this is at fault before we progress to an engineer for you.
EJ29768
Message 2 of 7
Hi Karl,
I've updated my phone number now.
Many thanks,
Message 3 of 7
Hi EJ29768
Can you check the home phone number in your 'Community Profile' , I'm not finding an active service with that number.
Message 4 of 7
Have you done a health check and run through the troubleshooting tips as detailed in the help article?
https://community.talktalk.co.uk/t5/Articles/Fix-a-dropping-broadband-connection/ta-p/2205305
EJ29768
Message 5 of 7
My router is a D-link DSL3782.
The firmware is v1.10t - last updated 14/12/18... surely that can't be right!?
paulshent
Message 6 of 7
An OCE will pick this up on Monday.  Available Monday to Friday working hours only
Can you state your router type and present firmware level.
