Fibre speed dropped to snail pace
JulianH
Message 9 of 9
As per title. The past few days have seen our fibre drop almost dial up speeds. My wife did some checks over the phone with tech i.e. line test, restart. But nothing was found. As I am the account holder she couldn't go further.
So what is the next step?
8 REPLIES 8
Message 1 of 9
Hi JulianH,
I've ordered the router, it should be with you within a couple of days but please allow up to 5 working days for delivery
Message 2 of 9
Can we get another router sent out ? if things look good on the line and at your end then that might indicate it's a router fault? My wife has already done the initial checks over the phone.
Pls advise
Message 3 of 9
No fluctuations it's consistently slow on both laptops
Message 4 of 9
Hi JulianH,
OK thanks. Sync speed is still 76Mbps. Do the speeds fluctuate or are they slow all the time? Are your speeds slower at certain times of day?
Message 5 of 9
No not just wifi. We have one laptop on wifi and one on ethernet cable.
Message 6 of 9
i'm showing the line in sync at 76mb and all tests are clear.
Do you see the speed drops only affecting devices over wifi ?
Message 7 of 9
Ok, done that now. Thanks
Message 8 of 9
If you would like the online support team to look into this for you make sure that your personal details including TalkTalk landline number are complete on your community profile (click here) so that they can link your forum identity with your account and then wait for them to respond.
