Fibre speeds significantly below 'promised' values
jadedfett
Message 6 of 6
Upgraded to fibre at the beginning of this year and initially the speeds were OK (around 36 down) However these speeds have dropped to close to what I was getting on ADSL, at best 26 down and at worst 20 down. Checking back at my speed test results shows a slow decline in speeds over the time I have had fibre. I am using the same HG633 router that I was using on ADSL and have carried out all the required troubleshooting steps, these tests are all carried out on a wired connection with all other devices off.
The most recent test I carried out was on the talk talk site which quoted my speed at 37 down, but on my router itself it quoted 27 down. There clearly is a problem somewhere along the line.
Could someone take a look at this for me please? Below is a tracert which may (or may not) shed some light on where the problem lies.
Tracing route to www.bbc.net.uk [212.58.249.208]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 * * * Request timed out.
3 8 ms 8 ms 8 ms host-78-151-229-209.as13285.net [78.151.229.209]
4 8 ms 8 ms 8 ms host-78-151-229-204.as13285.net [78.151.229.204]
5 21 ms 13 ms 13 ms host-78-144-9-37.as13285.net [78.144.9.37]
6 13 ms 13 ms 15 ms host-78-144-3-143.as13285.net [78.144.3.143]
7 * * * Request timed out.
8 14 ms 14 ms 13 ms ae1.er02.lbh.bbc.co.uk [132.185.254.142]
9 38 ms 37 ms 46 ms 132.185.252.130
10 14 ms 14 ms 14 ms bbc-vip146.lbh.bbc.co.uk [212.58.249.208]
Trace complete.
5 REPLIES 5
Message 1 of 6
Hi jadedfett,
Thanks for the update 🙂
Message 2 of 6
It is indeed, thank you for waving the magic wand!
Chris-TalkTalk
Message 3 of 6
Hi jadedfett,
I can see that your speed is back up to 40Mbps, please let us know if you experience any further problems
Message 4 of 6
Thank you for your response.
The routers uptime is currently showing as 2 days 7 minutes. The last reboot was when I swapped the microfilter to see if that would have an effect. I unfortunately do not have a test socket, the router is directly connected to the only phone socket in the flat.
Given my connection is in sync at 28mb, then that is a rather large problem given my quoted speed to be 39-40mb, what can be done to rectify this?
Message 5 of 6
Hi jadedfett
I've completed a line test which hasn't detected any faults and your line is in sync at 28.6mb.
There are some re connections showing on the line and this can affect the sync speed. Is the connection dropping or has the router been rebooted?
Is the router currently connected at the test socket?
