on 27-01-2022 12:39 PM
I'm upgrading from Faster Fibre to Fibre65. This change is supposed to happen today. After midnight, my internet went down and a solid amber light came on. Turned the router off for 30 minutes then back on again but the solid amber light remained.
Got up this morning to find internet connectivity has been restored but my account still says the Fibre65 order is pending. Is this normal? Also, will I lose internet connectivity again when the switch eventually happens - have a lot of smart products that rely on connectivity including Hive.
Thought this change would be easy - simply removing a speed limit.
on 27-01-2022 01:39 PM
Sorry, I misread your previous post, hadn't realised that you were already on a fibre circuit. Let me take a look at this and I'll get back to you
on 27-01-2022 01:30 PM
TalkTalk speed test reports speed to router is 39 Mbps. Speed to device 37 Mbps. Router Hub reports download speed of 40Mbps
on 27-01-2022 01:25 PM
OK thanks. If you're upgrading from faster fibre this is a different product, 'simply removing the speed limit' when upgrading to Fibre 65 would only apply if you were previously on Fibre 35.
Could you try a speed test and let me know the result
on 27-01-2022 12:51 PM
My existing package is called Faster Fibre
on 27-01-2022 12:49 PM
Hi JayPTee,
Did you upgrade from Fibre 35 to Fibre 65?
