Flashing amber on hub***
MRST1985
Message 3 of 3
My internet has suddenly dropped out, I have a flashing amber light, have done the line test, with no faults detected, tried switching off at the mains etc, pressing reset. Nothing works. The hub has been insitu for atleast 2years so no change in how it is set up..Home scholling again tomorrow..please help???
Message 1 of 3
Hi MRST1985
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 2 of 3
Hi @MRST1985,
If you have a landline phone can you check to see if that is working normally (i.e. you have a clear dial tone and no noise on the line).
If your master phone socket has a test socket then you could try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
Then they will hopefully be able to respond to this post within two or three working days.
You may get faster support from the live chat or by phoning up during opening hours.
