on 07-02-2019 08:01 PM
Since Tuesday I noticed that one of my sites I frequently use suddenly gives me this error "ERR_SSL_PROTOCOL_ERROR" . Upon googleing it, answers did come back but after trying the solutions mentioned problem still presisted. So I tried the website on different pc, laptop and mobile phone. No luck, so I tried it on my mobile phone but with mobile data instead of wifi and it worked. Conclusion home broadband!! So I reset the router, no change.
Contacted tech support no help other than we will escalate it.
Now whats really annoying me now, is that I get the same error message is coming up on loading Fortnite on PC and PS4 keeps re-trying to connect to server.
Also now all my settings are gone for home safe and it wont let me save my settings or let me turn it on.emoticon.sadtears.title
on 01-05-2019 11:10 AM
The error message ERR_SSL_PROTOCOL_ERROR error indicates that the browser is not able to initiate the secured communication at the moment. It's almost impossible to pin it down to a single cause, it could be almost anything. There is no definite guide for managing this error. However, there are few changes or settings which help you to get rid you of this error.
Configure Correct Date and Time
Clear Browsing Data
Clear Your SSL State
Disable QUIC Protocol of Chrome
Disable your Internet Browser Extensions
Adjust Your Internet Security and Privacy Level
Remove your system's hosts file
Check Your Antivirus Settings
Check Your Firewall
on 16-04-2019 01:18 PM
Hi NicolaC13
If you start your own thread (new message), we’d love to help.
We’ve found that posting in someone else’s conversation makes it harder to follow when looking for an answer.
It’s easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
on 15-04-2019 02:55 AM
I have been having the same problem with this error for the last few months. Every Monday at 00:00 it automatically disconnects my internet and every webpage has the ERR_SSL_PROTOCOL_ERROR regardless of browser.
I have tried turning my modem on and off for 20 mins, cleared all my browsers caches, checked they are all updated to the latest versions.
I opened a non-secure website and it opened a strange white page with a grey expanding box and that was it.
I have called and used the chat facility during the day but all I am ever told is to restart the modem. Seeing as the problem only occurs at midnight it is impossible to get someone to help me in real time.
I await your help.
Nicola
on 08-02-2019 11:07 AM
Hi shahidur,
Please can you update your forum profile to include your telephone number so that we can look into this further. To do this go into "my settings" then "personal information" then add your details.
Please do not post any personal information on the forum.
on 08-02-2019 09:01 AM
