on 21-03-2021 05:31 AM
I have just been given a free upgrade to fibre which says I go live on 31/3/2. I was advised to plug the new router in straight away when I received it which I did but the internet completely went down then came back on 5hours later eventually the internet stayed on ,but in the evening the speed drops to so low all devices attached to it stop receiving internet (wireless) .
I'm not very technically minded so rely on you guys to ensure things are running well . It does say that it will stabilise in 14days but cannot cope or wait that long and after reading another post regarding same thing I have turned the new router off and gone back to my old router with a stable internet. I have daughter at home whom needs to do lectures for university on line and has been unable to attend due to slow internet through the new router so I am sticking to my old router for now till I get some reassurance that the new one will be reliable and cater for my needs
Thanks Angela
23-03-2021 11:28 AM - edited 23-03-2021 11:30 AM
AngelaBeaumont
Which make and model of router is your old router?
If you would prefer to keep this connected and it's a fibre compatible router then you can continue to use this once the fibre goes live.
on 22-03-2021 08:21 AM
on 21-03-2021 07:57 PM
Most routers should connect within two or three minutes. Two hours is excessive and suggests something is not as it should be, especially if your old router connects without a problem. If you require steady and reliable internet all the time and can't get that with your new router but can with your old one I suggest you connect your old router and then await the reply from an OCE. Hopefully that may include the offer of a replacement of your new but perhaps faulty router, although they may have other things they can offer which solve your problems.
on 21-03-2021 06:57 PM
on 21-03-2021 06:13 PM
To speed things up you must ensure your personal details are filled in under 'My Profile' including your talk talk email and your TT landline number and an alternative telephone number like a mobile. This will help the OCEs identify who you are. Do not add personal stuff to this thread.
You can also check your service connection within 'My Account'.
If you have one of the older routers which is ADSL only (non fibre connectivity) and have it connected (rather than the router which you were sent) the exchange will not be able to connect you to fibre.
Finally if your old router works fine and the new router doesn't you are likely to have been sent a faulty router.
21-03-2021 07:51 AM - edited 21-03-2021 07:52 AM
Staff will reply during the week, @AngelaBeaumont.
It's best not to add to your post before getting a reply, to keep your thread moving forward in the queue for attention.
on 21-03-2021 07:46 AM
