Frequent disconnects
MacDuffer1
Message 8 of 8
Hi. For the past few weeks I have been having frequent disconnections at different times of day and night. Several times I have unplugged the router for over half an hour but it is syncing at 5.8 Mbps when before it was nearer 40 Mbps. I am using the test socket at the moment and while disconnects are less frequent, speeds are still slow.
There does appear to be noise on the line (crackling). I had a similar problem a couple of years ago with a previous supplier and the engineer traced the fault to there being water in the green cabinet in the street.
Many thanks.
7 REPLIES 7
Message 1 of 8
Hi MacDuffer1
That's great news, thanks for keeping us updated 🙂
Message 2 of 8
Hi Debbie
The engineer has just fixed the fault and all seems to be working well.
Many thanks for your help.
Message 3 of 8
Hi MacDuffer1
This fault has now been passed to an Openreach line engineer and we should receive further updates within the next 48hrs.
Message 4 of 8
Hi MacDuffer1
I've escalated this fault over to our Network Team for investigation and I will post back on this thread as soon as I receive further information.
Message 5 of 8
Hi Debbie
I have tried with just the phone connected and there is still hiss and occasional crackle on the line.
Many thanks
Message 6 of 8
Hi MacDuffer1
I've completed a line test which has detected a possible fault.
Noise on the line can affect the BB connection so we have to investigate this first.
Is the noise still present if you test with a corded handset at the test socket, with the router removed from the line?
I can then escalate this fault over to our Network Team for investigation.
Message 7 of 8
