Future Fibre 500 question...
Sulley43
Message 8 of 8
Hi, had future fibre 500 Installed last week , seeing speeds around 200mb to 300mb
Is there a settling in time for future fibre?
7 REPLIES 7
Message 1 of 8
Hi Sulley43,
Thanks for the update 🙂
Message 2 of 8
Ok I`m jealous now
Message 3 of 8
Looks like I've got it fixed , swapped the ethernet cable between modem and router and speeds are near smashing 500mb
Chris-TalkTalk
Message 4 of 8
Hi Sulley43,
How are you getting on?
Turkleton
Message 5 of 8
Are you testing speeds with a wired connection or WiFi? I hit about 200mbps on WiFi and around 460mbps on wired devices.
Message 6 of 8
Hi Sulley43,
Is this the sync speed that you're referring to or wired or wireless speeds?
martswain
Message 7 of 8
No.
However, once you get to those speeds you need to carefully consider internal cabling and WiFi adapter capabilities as they can become the limiting factors even if you have 500 Mbps at the incoming fibre link.
