Getting 17 Mbps download on Fibre 65
gavinbrattan
Message 10 of 10
I'm on the Fibe 65 package and a couple of weeks ago I noticed my download speeds dropped from >40 Mbps to 17 Mbps, without any changes to my configuration (router in the same place etc). The DSL Information page on the router reports:
Downstream line rate (kbit/s): 19996
Maximum downstream rate (kbit/s): 40564
I reported the issue via the online chat and they reset the router and then advised I plug the router into the master socket. There's 2 upstairs so I moved it, but I'm not sure which is the master. Neither have a test socket. I think they are old LJ4/1A with a junction box outside, but this doesn't mean much to me to be honest.
Anyway, I've left the router plugged into each socket with no improvement in speeds. The speed seemed to drop at some point without any changes from my side anyway so the problem seems more likely to be something out of my control.
Can you please investigate?
9 REPLIES 9
Message 1 of 10
I've re-run the line test now which is clear. It can sometimes take a little while for DLM to adjust the speed if the connection remains stable and the errored seconds are low.
Message 2 of 10
Thanks, following a router reboot I'm getting ~28 Mbps.
Do you know why it dropped to < 20 Mbps?
I used to get > 40 Mbps, will it get back to that speed at some point?
Message 3 of 10
Hi gavinbrattan,
Thanks for the photos. DLM has moved you to a faster profile and sync speed is up from 20.0Mbps to 32.3Mbps. If you've not see any improvement in throughput speed can you switch your router off for 30 minutes then switch back on and retest
gavinbrattan
Message 4 of 10
Sorry for the late reply, I've been away, now getting approx 19 Mbps download. I've attached a picture of the first socket into the house (the one with a black cable which I can see then running outside the house). The socket with the white cable is another one that I've tried using but I'm getting the same download speed.
first socket into the housefirst socket into the housesocket in another roomsocket in another room
Message 5 of 10
Hi Gavin
Ok, the master socket is usually the first socket that comes into the property.
Would it be possible to post a photo of this socket on this thread?
Message 6 of 10
I'm not sure which is the master socket. There are no other devices attached to the other sockets.
Message 7 of 10
I just tried a 30 restart, but no change unfortunately.
Message 8 of 10
Hi gavinbrattan
I've completed a line test which hasn't detected any faults and the line is in sync at 19.4mb.
Do you know which socket is your master socket? Do you have any devices connected to the other sockets in the house?
Divsec
Message 9 of 10
Hi @gavinbrattan  have you tried a 30 minute router reboot this often improves things as it causes DLM to reset
Your post has been flagged for assistance and you should hear soon but please remember that the staff here work office hours.
