Going round in circles with support - HELP!
lloydgreen80
Message 10 of 10
For the last few weeks I've been having problems with wi-fi connections dropping - my devices show full signal strength but there's no internet connection.
This is an intermittent problem that happens at least once a day, varying from a few minutes to longer.  Nothing has changed with my devices so I've assumed its a router issue.
I've been talking to support via Twitter for weeks and the problem isn't fixed.  All they want me to do is do the same test over and over again, tell me that the issue has been fixed but it hasn't been.  Today I've been asked to connect a laptop to the router to carry out tests but all they've asked me to do is a speed test and then said the issue is fixed.
I've tried setting my channels to auto as advised but this hasn't helped.
I've had stable service for years but the issue is now almost as frustrating as dealing with support.  I've been told on about 3 occasions that I need to buy new wi-fi equipment but as my existing equipment has been fine for years all I want is for my existing equipment to do what it was doing before - I don't need an upgraded router.
Please help.
9 REPLIES 9
Message 1 of 10
Hi lloydgreen80,
I can help with this, I've sent you a private message to get more information.
Thanks,
Jo
Gliwmaeden2
Message 2 of 10
The recording and processing of returned items appears to be quite chaotic, @lloydgreen80, and they don't always even demand the correct item.
Logging of its return seems to lag behind, whereas these chaser emails are sent out frighteningly efficiently.
We've been complaining about this for a year....
It's helpful if you have a certificate of posting or kept details of the tracking number.
Staff will be back on here from Monday.
I'll re-escalate this thread for attention.
lloydgreen80
Message 3 of 10
My new router works perfectly - thanks for sorting!
I returned my old router as requested but am now getting emails asking me
to return my set top box for some reason or be charged £50.  Can you have a look as I’ve not done anything with my TV service.
Cheers
Message 4 of 10
The router is on the way.
Message 5 of 10
Thanks Karl
That's great service!
Have a lovely Christmas.
Message 6 of 10
Hi @lloydgreen80 I would take up Karl's offer & if you still have problems after that, let me know & I will help you from there.
Message 7 of 10
The router you have HG635 is about 7 years old now so there is a strong possibility that this is starting to fail.   Would you like me to send a new router for testing to rule this out ?
Message 8 of 10
Thanks Keith
My TV box is a wired connection and doesn't have the same issue.
Speedtests are all good.  I've not looked at the lights when it happens but will do.
I've tried to split my devices across 2.4ghz & 5ghz but it seems to effect all of them when it happens which makes me think its a router issue.  I've not added an new wi-fi devices (but I get that there may be changes in the local environment that I would never know about)
I'll have a look at the lights though the next time it happens and update here.
Cheers
Message 9 of 10
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
