Guests SSID has no internet access
Velin92
Message 2 of 2
I recently configured on my TalkTalk router through the advanced settings, an additional guests SSID, since I wanted to separate my personal wi-fi from the one that the guests that I will be having at home will use.
However while the SSID appears, and I am able to connect to it, the guests SSID and only such SSID, is unable to access the internet.
The default SSID works fine, the issue is only happening on the additional SSID.
Am I the only one experiencing this issue?
1 REPLY 1
Message 1 of 2
Hi Velin92,
Which router are you using? (make and model)
