on 05-04-2019 09:41 AM
When I first switched over to VDSL from ADSL2 I was supplied a HG633 this was working well except I was never happy with the WIFI performance on 5GHz.
Recently the HG633 started to make a high pitch audible noise I believe this was coil whine and started to really become a problem as it is located in the living room.
Internet speeds were stable and largly on the higher end of what what was expected and hardly dropped.
However more recently it did start around the same time as the whine it was getting after the recent contract renewal when we upgraded between 56-63MBps however lately it is strugling to get past 53MBps even after switching of for 30 minutes this didn't get better. I think this has caused the DLM to drop.
A while back we were also supplied a DSL-3782 which was only used when the HG633 had firmware problems before I was enrolled into the testing phase of the HG633 firmware before that was rolled out to all customers. I've started using this again two days ago however I woke up this morning to the biggest drop in some time down to 45MBps after a quick reboot this increased to 50MBps. The WIFI on the DSL-3782 is a huge improvement over the HG633 on 5GHz is much stronger and maintains a somewhat better max speed expected for the network bandwitch for dual band wifi, not perfect but a better result.
I know where to look for speeds which is always on the modem settings pages which is where I base all this knowledge from for speeds of the hardware.
So why at first was it at the maximum advertised and beyond expectations and more recently this has landed on the much lower end of advertised speeds? Fortunatly this is only £2.50 a month on the deal we were offered but when this goes up to £5 I can't justify the benefit of 5MBps for £5 a month so unless this is resolved when the time comes I will return to the old package at only a marginal speed difference.
This is what I always look for and not speedtest results.
Link Rate:
19113/50066 Kbps |
I fully understand what I'm looking for with speeds, and because I can not change the DNS for this I can not get speedtest results that come close to what the link rate is showing it falls short by 4MBps down and 2MBps up.
I've now plugged this into the test socket ready for any testing that is required following what seems to be required when support is provided. I do hope this returns to the higher speeds that I had when we first enrolled to the extra fiber speed boost package.
on 15-04-2019 11:39 AM
Hi G_R_UK_T4LK2M3,
Could you switch your router off for 30 minutes then switch back on and check to see if sync speed improves
on 15-04-2019 09:09 AM
on 14-04-2019 11:19 AM
I'm still using the replacement that was arranged for me.
on 12-04-2019 03:00 PM
on 12-04-2019 01:38 PM
Hi G_R_UK_T4LK2M3
Are you currently using a HG633 router? Has this been connected to the line for at least 48hrs?
on 12-04-2019 01:04 PM
on 11-04-2019 09:36 PM
The Hg633 is one of talk talk disasters, there is constant faults with them, I work for the company that provide talk talk with engineers and literally 1000's get sent back to the warehouse as faulty every day, a lot of routers get refurbished and reinstalled, I would ring talk talk and ask for a brand new router updated free of charge.
on 11-04-2019 09:29 AM
Thanks for the update
Your profile was changed which will cause a connection drop
11-04-2019 08:31 AM - edited 11-04-2019 08:34 AM
Some improvement in speed already, but I did notice a connection was dropped during this time or is this so they can release the higher speed?
Upstream line rate (kbit/s): 20000
Downstream line rate (kbit/s): 52476
Upstream noise safety coefficient (dB): 6.3
Downstream noise safety coefficient (dB): 6
Upstream interleave depth: 1
Downstream interleave depth: 13
Line standard: VDSL2
Upstream line attenuation (dB): 6.6
Downstream line attenuation (dB): 14
Upstream output power (dBm): 7.5
Downstream output power (dBm): 13.2
Channel type: Interleaved
on 10-04-2019 01:29 PM
Hi G_R_UK_T4LK2M3,
As the sync speed improves the SNR will generally drop, you don't need to do anything at your end
on 10-04-2019 12:48 PM
on 10-04-2019 12:14 PM
Hi G_R_UK_T4LK,
Thank you for keeping us updated. It can take between 24-48hrs for DLM to make changes to the sync speed now that the replacement router is connected. Hopefully DLM will start to increase the speed again over the next few days.
on 10-04-2019 11:48 AM
on 09-04-2019 10:54 AM
Hi G_R_UK_T4LK2M3,
If the connection remains stable and there are low errored seconds on the line then DLM should increase the sync speed. Please let us know once the replacement router is connected and we can re-check the connection stats again to see how they compare.
09-04-2019 10:15 AM - edited 09-04-2019 10:39 AM
Why / How can DLM even be allowed to set the profile below the minimum garanteed speed of the boost that was outlined to us in the contract renewal? DHL would have delivered today but I am not available for most of the day so I've set it for delivery tomorrow that's briliant quick delivery. Will update tomorrow once it has arrived.
Speed still low however the noise safety coefficient has gone down which is looking to be a good sign? Also connection is stable no loss in almost 18 hours so something very wrong with 3782 VDSL2 setup. Hope tomorrow HG633 will be fast connection again and stable wifi and silent like this HG633 used to be.
on 09-04-2019 06:19 AM
Hi G_R_UK_T4LK2M3,
I'm sorry to hear this. Unfortunately we can't make any manual adjustments to the speed as this is managed by DLM to provide the best balance between stability and speed for the line. If the connection remains stable then DLM should start to increase the speed within 24-48hrs.
Please let us know how both the stability and speed compares once you receive the replacement router.
08-04-2019 04:08 PM - edited 08-04-2019 04:12 PM
Can you do anything remotely please?
Now just had a few hours power cut thought I might as well switch back over to the HG633 and I have these results:
Upstream line rate (kbit/s): 17374
Downstream line rate (kbit/s): 35471
Downstream noise safety coefficient (dB): 8.4
Upstream interleave depth: 375
Downstream interleave depth: 2985
Downstream line attenuation (dB): 14.6
Upstream output power (dBm): 7.6
Downstream output power (dBm): 13.3
Something is very wrong this is way worse than it was even without the boost.
on 08-04-2019 12:16 PM
Hi G_R_UK_T4LK2M3,
I've ordered a replacement router, should be with you within a couple of days but please allow up to 5 working days for delivery
on 08-04-2019 11:47 AM
on 08-04-2019 11:38 AM
If the HG633 router is making a noise then it does sound like this router could be faulty.
