Have to Reboot Router every couple of days
stevec99
Message 5 of 5
Over the last few months I have had to reboot my router more and more often.
It used to be I'd have to reboot once or twice a month.
Now I have to reboot several times a week, the internet connection drops, some times it comes back. most times I have to reboot and the connection is stable for a while.
I mainly work from home now and this is becoming a problem.
Could a replacement router be provided.
4 REPLIES 4
Message 1 of 5
No Problem 🙂
Message 2 of 5
Hi Karl,
I have received my replacement router and installed it.
Hopefully this will sort out my problems.
Steve
Message 3 of 5
i'll get a router out to you and see if this helps.
Message 4 of 5
They aim to respond within 48 hours (Monday - Friday), but if more urgent you can always try the Service Centre. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk have responded to you, otherwise, this will just put you further down the queue.
