Having to reboot router every 1-2 days
rjoseph
Message 8 of 8
For the last couple of weeks I've had to reboot the router every day or two in the morning.  Nothing has changed in our setup - the router is plugged into the master socket.
Some mornings the internet speed (wired and wireless) is below 1mbps.  As I type, I've just had a download speed of 2.8 mbps so I'll need to reboot to allow me to work.
Rebooting sorts it until it slows again, which suggests might be a router issue?
Thanks in advance
7 REPLIES 7
Message 1 of 8
Message 2 of 8
Will do - thank you for the quick replies.
Message 3 of 8
Hi rjoseph
Let us know how the connection compares with this router,
rjoseph
Message 4 of 8
That would be great, thank you.
Message 5 of 8
Hi rjoseph
I can send you a replacement router for testing would you like me to arrange this?
rjoseph
Message 6 of 8
Yes, it does also affect the wired devices.  We have a Sky box and Xbox on wired and they slow down the same as the wireless devices.
Message 7 of 8
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault. Can I just confirm, does this also affect the wired speeds?
