Having to reset router- new router required.
kevjin
Message 6 of 6
Hi there TT advisors,
I have to constantly reset my router to get my promised fibre speeds. This has been an issue since I joined TT in October. Reading through posts in this community, it seems that a new router may solve the issue. Would it be possible for one of you guys to expediate this request?
Kind regards,
Kev
5 REPLIES 5
Message 1 of 6
No Problem 🙂
Message 2 of 6
Thank you, Karl!
Yes, it's been an issue I have raised in the past (over the phone and via chat). All tests came back clear. The only thing that resolves the problem is resetting the router, which is an inconvenience and only a temporary fix.
I look forward to receiving the new router and determining if that is the problem.
Message 3 of 6
All tests are clear, nothing obvious showing.
I've a replacement router on the way to rule out a hardware issue.
Message 4 of 6
Thanks for the information. I will update my profile accordingly.
The connection slows immediately. It doesn't drop out completely. This happens both wired and over wifi. I have the TalkTalk Wifi Hub (Black).
Skynet_TX
Message 5 of 6
Hi @kevjin,
What problems are you seeing, does the connection completely drop (if so what do the light(s) do on the router when this happens), or does the connection just go slow (and if so, does the speed gradually drop over time, or just suddenly drop) ?.
Does the issue affect wired or wireless devices (or both) ?.
What make / model of router do you currently have ?
Then they will hopefully be able to respond to this post within a working day or two.
