Help Please with broadband speed
redmikekite
Message 19 of 19
Hi recently I have been having issues with my internet speed dropping into my router, Its always a constant 40mbps with a speedtest results of 37mbps with an ethernet to pc connection and around the same or slightly less over wifi, I currently use a netgear nighthawk which is 3 years old now this has been going on for about a month and I usually have to reset the router and it comes back but today its got worse so trying to rule out the connection I have connected a brand new talktalk router which I received after renewing my contract in june. So the speed going into the talktalk router after setup was 19.5mbps so I rebooted and the speed going into the talktalk router has jumped up to 40mbps which is great but when i do a speedtest over ethernet my download speed has dropped to around 18mbps which i cant understand as the speed into the new router is 40mbps and previously the down load has always been around 37mbps via speedtest and talktalk speedtest. Does any one have any ideas? I am stumped i have reset my pc network settings and checked everything. I have a fairly new high spec gaming pc which I built my self which has two network work adapters and I have tried both. any help would be greatly appreciated, its strange as my connection and speeds have always been constant which is why I stay with talktalk.
18 REPLIES 18
Message 1 of 19
Hi Mike
I'm glad to hear that the connection has remained stable. If you do experience any further issues then please let us know.
Message 2 of 19
Hi Debbie
new router connected had a few issues so as my openreach mk4 socket has a built in filter i took the front off and connected it to the test socket with the new micro filter provided and so far so good its been completely stable so I will leave it like this and if it continues to be fine I will replace the mk4 socket front. once again many thanks for the quick response as I said previously I believe the community is the way to go if you need help.
Kind regards
Mike
Message 3 of 19
Hi Mike
That's great 🙂
Thank you for your kind words, It's appreciated 🙂
Message 4 of 19
Hi Debbie
thanks for your help just had notification from yodel delivering today which will be the router, my microfilter is built into the socket so i will use the test socket with a microfilter and see what happens. Many thanks again for your help, i find the talktalk community a great asset for help and adivice, its really appreciated in theses difficult times.
regards
Mike
Message 5 of 19
Hi Mike
Thanks for your reply. Yes this could be the router or the microfilter.
Hopefully you will receive the replacement router today.
Message 6 of 19
Hi Debbie
im at work at present but funny you should say that when i disconnected it yesterday the noise did go when the router was unplugged from the socket so would this indicate its the router then ?
regards
mike
Message 7 of 19
Hi Mike
Is the noise still present on the line if you remove the router? Is the noise still present at the moment?
Message 8 of 19
Hi Debbie
No not yet
Mike
Message 9 of 19
Hi Mike
Message 10 of 19
Hi Debbie
my internet stopped completely this evening started working again after router reset but speed has dropped in to router also there is alot of cracking noises on the phone line which i did not have before, any ideas?
regards
Mike
Message 11 of 19
Message 12 of 19
Many thanks Debbie
I will let you know how I get on I really appreciate your help
regards
Mike
Message 13 of 19
Hi Mike
The router is on its way and a returns bag for your current router.
Please allow 24-48hrs for this to arrive. Let us know how the connection compares with this router.
Message 14 of 19
Hi Debbie
yes that would be most helpful would you like me to return the new talktalk router I received when I renewed my contract? that model is a sagecom fast5364-3.T8 serial number is N7200654N006637
Mike
Message 15 of 19
Hi Mike
Apologies for this.
Would you like me to send a different make and model of router for testing to see how the connection compares?
Message 16 of 19
Hi Debbie yes it usually does and seems to work fine for a while sometimes it’s good for a couple of weeks then plays up again hence swapping out the router for a new talktalk one but this still had the same issues I had a family member who works for a well telecommunications company check my wiring inside my house and all is good so I’m really stumped but so far it’s running ok but I’m not sure how long this will last. I had a couple of issues in the past two years which were problems at the cabinet. So I don’t know what else to do
regards
mike
Message 17 of 19
Hi redmikekite
Just to confirm, does the speed always increase after the router has been rebooted?
Skynet_TX
Message 18 of 19
Hi @redmikekite,
Have you tried switching the router off for over 30 minutes, then when you switch it back on it will start a new 'session' in the street cabinet.
I've had this exact same issue when moving between two different models of TalkTalk supplied router, the new router will sync at 40 but only give me 28 in throughput until I force a new session with a +30 minute shutdown.
