Help, keep loosing signal
Paul123E
Whizz Kid
Message 25 of 25
Would you please be able to check my line?
For the last couple of days, especially mid morning onwards, the router is loosing a signal every few minutes. Speed has also dropped down (as reported by the router). It is getting very difficult to work now.
Also, did you upgrade my router firmware about a week ago? All my iDevices lost connection to 2.4Ghz Wifi and I had to make router setting changes to get them to connect again?
(just happened again when I pressed the 'post' button).
Paul E
24 REPLIES 24
Message 1 of 25
Hi Paul,
Thanks for the update and please let us know how the stability compares over the next week.
Thanks 🙂
Message 2 of 25
Just an update;
Engineer came Friday afternoon. The line stats all behaved whilst he was here but he did detect some possible damage to the overhead cable from accross the road that comes into the house.
He got a cherry picker in and had the cable replaced in 2 hours. Since then the signal has been solid with no dropouts so it looks like he may have solved it. I will keep monitotring but am sure the problem is now fixed.
Thanks for everyones help and thanks to the OpenReach man who was very helpful and was determined to fix the issue.
Paul E
Message 3 of 25
Hi Paul
Please let us know how you get on following the engineer visit.
Message 4 of 25
OpenReach engineer home visit booked for tomorrow afternoon.
I will report back once complete.
Paul E
Message 5 of 25
Hi Paul
Apologies for this.
I've completed another line test which is still detecting a possible fault.
I've passed this back to Openreach as a repeat fault and I will check on this again tomorrow. Apologies again for this.
Message 6 of 25
OpenReach were out today (it went off for 30 minutes and I saw a man up the pole opposite the house). I also had an email and text that pronounced it fixed.
30 minutes later it went off and has been off and on ever since so I do not think they did anything to resolve it.
In general, it appears to be OK in the morning, its the afternoon when it gets unstable.
Paul E
Message 7 of 25
Hi Paul
Thanks for the Private Message 🙂
I've now escalated this fault over to Openreach to be investigated by a line engineer.
We should receive further updates from Openreach within the next 48-72hrs.
Message 8 of 25
PM Sent.
Thanks for the support.
Paul E
Message 9 of 25
Hi Paul123E
Apologies for this.
I've completed a line test which has now detected a line fault.
Please can you send me a Private Message to confirm the name on the account, I can then raise this fault over to Openreach.
Message 10 of 25
Also checking router logs I see and entry for 'DSL connection is disactive' followed by 'WAN connection INTERNET_TR069_R_VID_101:IPv4 disconnected.(ERROR_NO_CARRIER)', there is then a 'DSL connection is active.' when it comes back up.
And it just went middle of writing this. Upstream rate is now a third of normal value on this reconnect.
Please can you get OpenReach involved again?
Paul E
Message 11 of 25
So the connection was rock steady all day until about 4:30pm.
Then the signal dropped and kept comming and going. It has now been up for around 30 minutes after disconnecting and reconnecting a number of times.
I have noticed that when the signal was good, the Upstream and Downstream Noise Safety Coefficient are both around 6dB. When the issues occurr the upstream especially goes all over the place from 0 to 15. The downstream is also changing but not by as much. This also seems to match the upstream speed also changing by big amounts on every reconnection. At the moment the upstream is still changing on almost every refresh.
Does this mean anything?
Paul E
Message 12 of 25
Hi Paul
Debbie 🙂
Message 13 of 25
Back on the old HG635.
It has synced up with a faster upload/download speed than the Sagemcom and been stable for the past 30 minutes.
I will report back later once I have worked for a while with it.
Thanks for your continued support.
Paul E
Message 14 of 25
Hi Paul
I've completed another line test which hasn't detected any faults but I can see re connections on the line.
Have you tested with a Huawei WIFI hub?
Message 15 of 25
Still dropping out every so often (usually the moment I have a meeting).
Speed appears to be dropping down steadily.
I need it investigating please.
Paul E
Message 16 of 25
OK, I will keep an eye on it for now. It appears to have been stable since lunch.
Thanks again.
Paul E
Message 17 of 25
DLM can often drop when there is an issue detected on a line, and once resolved it will normally reset after a few days.
Message 18 of 25
Should have said. Upload speed half of what it normally is and download speed lower than usual (as reported by router). If it stabalises maybe they will go back to normal?
Paul E
Message 19 of 25
The router is dropping out and being disconnected.
It has been stable for the last hour or so. I will keep an eye on it for now.
Paul E
Message 20 of 25
Hi Paul
All tests are clear, nothing showing when tested.  Are you seeing the drops over a wired connection or just over wifi ?
