Here we go again: DLM SLOW TO RESTORE DOWNSTREAM SYNC SPEED.
album56
Message 31 of 31
The downstream VDSL sync speed dropped to 41Mbit/s a couple of weeks ago & hasnt changed despite switching router off for 30mins etc to try to get DLM to activate.
The router info:-
Upstream line rate 20Mbit/s
Downstream line rate 35Mbit/s
Max upstream line rate 21Mbit/s
Max downstream line rate 88Mbit/s
Upstream noise margin 6.1db
Downstream noise margin 13.2db
Upstream interleave depth 1
Downstream interleave depth 2977
So I still have a very underperforming fibre broadband with speedboost.
The speedboost has worked for periods but seems very unreliable.
This has been ongoing problem, sometimes for a week the downstream sync speed will be 61 Mbit/s then the internet light turns red & I loose all connection until I reboot the HG633 router which restores connection at a much lower sync speed.
I am desperate for fttp to stop all this nonsense with hybrid fibre/copper.
30 REPLIES 30
Message 21 of 31
Hi Mike
Let us know how the connection/speed compares with this router.
Message 22 of 31
Hey mike, completely agree with you regarding the speed cap not reflecting the sync speed and adjusting up.
Message 23 of 31
Hi Michelle
If you think its worth trying another router then yes if it sorts the problem out that would be great.
It looks to me though downstream speeds are deliberately capped going by the number of people with the same problem on here.
Regards Mike
Message 24 of 31
Hi album56,
I've just re-read through your topic and I can see that you're using a HG633 router. Can I just confirm, have you ever tested with a different router? If not then I think we should try a different router to see how the sync speed compares?
Message 25 of 31
Hi Michelle
Openreach have not contacted me, it doesnt appear if anything has been done.
As you rightly say downstream sync speed is still appears to be capped.
Regards Mike
Message 26 of 31
I'm sorry for the delay. I've re-run the line test now which is now clear, however the sync speed hasn't increased but the connection looks more stable. Just to confirm, did Openreach make contact with you?
Message 27 of 31
Hi Karl,
Still downstream sync speed is capped ?
Upstream sync 20,000 Mbp/s
Downstream sync 35,495 Mbp/s
Upstream noise safety margin 6.1db
Downstream noise safety margin 13.5db
Downstream interleave depth 2987
I have been on this journey several times before, if I wait for 1 week maybe 2 then DLM might decide to re-sync at a higher Downstream speed, it has been as high as 61,000 Mbp/s previously but after a week or 2 at those heady speeds I'll suddenly loose the internet connection with red light etc. Then the only way to restore connection is a router re-boot & Downstream sync speed drops drastically again.
Cityfibre are currently putting fibre in the ground here, wont I be glad to see the back of the unreliable hybrid fibre/copper broadband.
But its going to many months yet before FTTP becomes available, in the mean time please can you sort this for me.
Regards Mike
Message 28 of 31
Let's see what openreach come back with tomorrow.
Message 29 of 31
Thanks Karl, yes I've noticed doing the 30min router reboot doesnt reset the sync speed, looks like my downstream sync speed has been capped artificially low.
Message 30 of 31
Tests are showing there is a network outage on the Openreach side.
I've logged a fault to Openreach for investigation to see if this is related.
