Heya! My internet box has been flashing orange for 2 days!!! I have reset it and turned it off.
Daniella
My box has been flashing orange for 2 days now I have reset it and turned it off and bavk on and nothing seems to make it work!
Skynet_TX
Hi @ Daniella,
It would be worth going to the Service Centre to ‘Run a live connection test’ on your phone line, this will indicate if there is currently a fault on your line. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
The staff on this community won't be around until Monday now, so you may get faster support by using the live chat or phoning up over the weekend, however the staff here should respond to this topic early next week to help if you are still having issues.
OCE_Debbie
Hi Daniella
  • Name
  • Telephone number
  • Alternative contact number
