on 07-08-2019 09:03 AM
My router resynced automatically a few days ago.
My old sync rate was around 32mb down and speeds to match, 29/30mb.
The router is now synced at 37mb down but i've no speed increase.
My question is, will my download speed increase automatically at some point or is there some sort of profile that needs manually changing at your end?
on 08-08-2019 06:02 AM
Hi CuzUK,
Thanks for the update 🙂
on 07-08-2019 03:57 PM
Sorted😃
Turned off router for 40 mins, rebooted and now synced at 37.5mb.
I should be getting 35mb download speed so close enough👍
on 07-08-2019 01:22 PM
Hi CuzUK,
Could you try switching your router off for 30 minutes then switch back on and retest
