How can I set WiFi hub to modem mode
timsimpson
Message 2 of 2
I have a Sagemcom talktalk WiFi hub, and have connected a Linksys Velop system to it. I would like to use the velop system as the router, do I'd like to set the talktalk WiFi router to work in modem mode or bridge mode.
How can I do that?
Any advice would be gratefully received.
Thank you
1 REPLY 1
Message 1 of 2
You cannot use the wifi hub in modem only mode or bridge mode, but can still connect another router from the ethernet port to the wan port of the 2nd router.  You may need to change the IP range of the other router so there are no clashes etc.
