How can I set my router to allow my laptop to print wirelessly to my printer?
Julia_73
Message 3 of 3
My laptop can’t connect wirelessly to my printer and I think the restriction is to do with my router. Can I connect to my router directly and change something to allow me to print wirelessly?
Julia_73
Message 1 of 3
Hi Julia_73
Have you tried splitting the SSID's on the router? Split your router's SSID (wireless network name)
My printer will only connect using 2ghz.
Message 2 of 3
The usual thing is to try and set a fixed IP address for the printer, and work from there.
OR
Use the WPS function on the router, usually a button to press, and this allows almost anything to connect for the next 30 seconds.
https://www.lifewire.com/what-is-wps-4842308
https://www.talktalkbusiness.co.uk/wifihubsetup/set-up-your-wifi-hub/
If in doubt please ask.
