on 19-10-2020 10:44 PM
I have a Floureon camera system and Hard drive currently connected to a TV upstairs by HDMI (where I used to have my office).
Ive now had to move my office downstairs and I want to be able to check the cameras on my computer which is connected to the HG633 router.
I have run an ethernet cable from the DVR to a Cisco Network switch and then to the router. The switches lights are both on and flickering and in the LAN settings for the router it shows the LAN as connected at 100MBPS.
I sort of hoped the connection would set itself but Im afraid im at the limit of my knowledge. Does anyone have a step by step guide they could point me at to enable me to set the Router up and if necessary the DVR. Im OK at following instructions but just not very familiar with all the terms used. Thanks in advance.
on 27-10-2020 11:12 AM
on 27-10-2020 10:57 AM
I have had a look at the trace, the TCP sessions all establish OK as do some HTTP sessions, so there is no problem with closed ports or anything. Whatever the problem is it is down to the browser plugins or whatever, it is not a network issue at all. I would suggest you take this up with the manufacturer of the CCTV.
on 26-10-2020 04:42 PM
on 26-10-2020 04:28 PM
I'll try & have a look at this tomorrow for you. I will delete your trace from your post to protect your security.
on 26-10-2020 04:18 PM - last edited on 26-10-2020 04:28 PM by KeithFrench
File from Wireshark
on 26-10-2020 03:58 PM
First within Wireshark identify the connection from your PC to the router, as I said I am guessing that your PC is connected via wireless. Click on that interface & start the trace as per my guide.
Then (even though you know it won't work) try & connect to the CCTV from Chrome or Edge on your PC. Once you get a message back saying that you were unable to connect, or whatever it might say, stop the Wireshark trace. Then follow my guide on how to save the trace & send it to me.
on 26-10-2020 03:33 PM
Just for info, in your Wire Shark instruction you say when the Once the application has failed, what does that mean?
Do I just leave it running until it stops itself? Or should I stop it after a number of lines
on 26-10-2020 03:24 PM
Just for info, we have a DVR on our CCTV system in Thailand and that will only work with Internet Explorer as the required plug-ins are not available for any other browsers.
on 26-10-2020 03:10 PM
How is the PC connected to the router, maybe it is WiFi, not Ethernet? You may have to select the Npcap Loopback Adapter.
on 26-10-2020 03:03 PM
Sorry for the delay. I thought I had actually responded last week.
I connected the DVR directly to a cable off the router and and redid the previous tests, and got the same results (see attached) . Ive followed your Wireshark instructions and the result is as shown in the attachment. Neither of the Ethernet connections shown appear to have any activity. Clicking on either of them and running a trace does not show any results. There are Two connections to the router DVR and Hive controller
on 21-10-2020 09:32 AM
Thanks for that. I will try to do that during the week. As ill need to move the DVR to try it. Appreciate your help.
on 21-10-2020 08:53 AM
I have just remembered that the HG633 has a problem when devices are not connected directly to either LAN or WiFi interfaces (e.g. via a switch as in your case). They are OK for general internet access but not for devices trying to connect to them.
Just to prove this is the case first, please can you try temporarily connecting the CCTV directly to a LAN port on the router? If it works then, that is the issue, if it doesn't, then I will need the Wireshark trace.
on 20-10-2020 08:50 PM
Id appreciate it Keith. Ive just spent a couple of hours "fiddling" and still no further forward.
on 20-10-2020 08:48 PM
I would guess that the port on the CCTV is not open, but the only way to prove this is by you using Wireshark to get me an IP trace of what is going wrong, so I can analyse it for you. Do you want me to send you a guide on how to do this?
on 20-10-2020 04:23 PM
Similar in both Chrome and Edge
on 20-10-2020 04:07 PM
OK, now in Edge or Chrome, what happens if you try & go to:-
on 20-10-2020 04:00 PM
Ive just looked on the DVR and it says TCP port 34567 and HTTP Port 80
on 20-10-2020 03:42 PM
Yes, that is exactly what I wanted to prove. What TCP port do you connect to this CCTV with?
on 20-10-2020 03:36 PM
Ok thanks
There you go. I suppose that proves it is connected
on 20-10-2020 02:54 PM
OK, another way then. What is the IP address of the CCTV, you may need to log into the router for that? Then on the PC go to a command prompt & type
ping 192.168.1.x
substituting the actual IP address of the CCTV for the 192.168.1.x and press the enter key. Give me a copy of the output from this command.
