How to reset my talk talk router
Golfboy
Message 3 of 3
My smart TV connected to my router via cable works fine, but my latest apple iPad struggles to connect wirelessly just 3 metres from the router.
how do I reset my router
Message 1 of 3
Hi Golfboy
did you manage to connect your device ok ?
paulshent
Message 2 of 3
You can recycle the router power and then retry or do a factory reset by pressing the reset switch on the rear for a good 15 seconds
Also try splitting your 2 and 5ghz  wifi in the router
