on 06-01-2022 08:42 AM
Can I request the 1.06t firmware update to my Huawei DG8041W router that is currently running 1.05t?
My broadband connection appears to be reliable now (up for 67 days) but my router is restarting regularly causing internet to go down for devices. Here is some info from the router user log file:
2021-12-23 23:36:45 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-12-23T23:36:45.850Z
1981-01-01 00:00:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
2021-12-24 17:50:57 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2021-12-24 17:50:57+00:00], uptime is [35s].
2021-12-24 17:51:29 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-12-24T17:51:29.661Z
2021-12-24 19:22:40 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2021-12-24 19:22:40+00:00], uptime is [34s].
2021-12-25 19:23:13 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-12-25T19:23:13.319Z
2021-12-26 18:40:55 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2021-12-26 18:40:55+00:00], uptime is [34s].
2021-12-28 18:41:30 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-12-28T18:41:30.176Z
1981-01-01 00:00:09 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
2021-12-29 00:50:54 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2021-12-29 00:50:54+00:00], uptime is [36s].
2022-01-03 00:51:26 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2022-01-03T00:51:26.762Z
2022-01-03 18:20:58 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-01-03 18:20:58+00:00], uptime is [35s].
2022-01-05 18:47:20 [Critical][Config-Log] Terminal:WEB(192.168.1.11),Result:Success,Type:Logout,Username:admin
2022-01-05 23:36:04 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-01-05 23:36:04+00:00], uptime is [35s].
Thank you.
Answered! Go to Solution.
on 03-05-2022 10:23 AM
Please can you create your own topic and we'd be happy to take a look at this for you.
on 29-04-2022 12:39 PM
Hi I am having the same issue. Can I request the 1.06t firmware update to my Huawei DG8041W router that is currently running 1.05t?
on 06-01-2022 09:15 AM
Hi alocke
No problem 🙂
on 06-01-2022 09:10 AM
Hi Debbie,
Thank you for the extremely quick update! I can see the router has now been updated to 1.06t. I'll monitor the router in the coming days and see whether I get any more kernel panics/restarts.
on 06-01-2022 09:07 AM
Hi alocke
Apologies for this.
I've made a change to the FW, please let us know how the connection compares.
