Huawei DG8041W router kernel panics
kashms
Message 5 of 5
The TalkTalk provided router has for some time now been losing connection for a few minutes close to everyday. This has become an annoyance when there are two of us working from home.
Looking into the logs of the router I see the following entries
1981-01-01 00:00:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
2021-05-02 18:52:01 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2021-05-02 18:52:01+00:00 DST], uptime is [76s].
2021-05-02 18:52:03 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2021-05-02 18:52:14 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-05-02T17:52:14.484Z
1981-01-01 00:00:09 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
I have seen other people on this forum with similar problems that have had a firmware update applied that supposedly fixes this problem.
Can one of the TalkTalk staff please have a look?
4 REPLIES 4
Message 1 of 5
We'll be here if you need us 🙂
Message 2 of 5
Thank you Debbie!
I will monitor over the coming days.
Message 3 of 5
Hi kashms
I've made a change to the router firmware, please can you retest and let us know how the connection compares?
Message 4 of 5
Yes you are correct it needs a firmware update to fix this. I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you.
They aim to respond within 48 hours (Monday - Friday), but if more urgent you can always try the Service Centre. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk have responded to you, otherwise, this will just put you further down the queue.
