Huawei HG535 WiFi dropouts
Raymond Duck
Message 3 of 3
Hi, recently our 2.4Ghz WiFi keeps dropping out. LAN and 5Ghz are fine. Resetting the router makes no difference; on the WiFi checker app you can see the signal, then it vanishes.
This seems to pop up in the forum from time to time. Did anyone get a solution?
Really I'd like TalkTalk to send me a new router to try...
Message 1 of 3
Hi Raymond,
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 2 of 3
Hi @Raymond Duck,
Have you tried changing the channel that the 2.4GHz band is using, just to see if that has any affect on the problem ?
Then they will hopefully be able to respond to this post within a working day or two.
