Huawei HG633 firmware update request
rad81
Message 14 of 14
I have recently upgraded to Fibre65 but cannot see any improvements, so I am wondering if this may help?
I have reset the router.
Hardware version:
H.1.01
Software version:
v1.15t
Many thanks,
13 REPLIES 13
Message 1 of 14
Hi rad81
Sorry for the delay.
I've checked and your router has the latest firmware version - v2.00t
Would you like me to send a replacement router for testing?
Message 2 of 14
No worries, sit tight and I am sure the support team will give you all the help you need.
Message 3 of 14
Ok, thank you again!
Message 4 of 14
I honestly don't think that's an issue, but the support team will advise anyway.
Message 5 of 14
Thank you for your help. I will update my details.
So going back to my original question. Would it be a good idea to upgrade the router's firmware anyway?
Best regards
Message 6 of 14
OK, thanks for that. What were your previous speeds like? On the face of it, it looks like your line cannot support Fibre 65 so I am surprised that you were allowed to upgrade.
If you make sure that your personal details including TalkTalk landline number are complete on your community profile (click here) so that the online support team can link your forum identity with your account and then wait for them to respond. It will not be before Monday at the earliest, but rest assured they will look into this for you.
Message 7 of 14
Thank you,
Please see below:
DSL synchronization status:
Up
Connection status:
Showtime
WAN IP Address:
89.243.140.251
Primary DNS Server:
79.79.79.79
Secondary DNS Server:
79.79.79.80
Line Quality
Upstream line rate (kbit/s):
4296
Downstream line rate (kbit/s):
16495
Upstream noise safety coefficient (dB):
11.1
Downstream noise safety coefficient (dB):
17.1
Upstream interleave depth:
95
Downstream interleave depth:
1429
Line standard:
VDSL2
Upstream line attenuation (dB):
7.2
Downstream line attenuation (dB):
17.3
Upstream output power (dBm):
-4.7
Downstream output power (dBm):
12.4
Channel type:
Interleaved
DSL up-time:
0 days 1 hour 45 minutes 40 seconds
Message 8 of 14
Ignore all that, it is not relevant to your speed issue.
I have since found this:
  1. Open your browser and type in 192.168.1.1 to go to the router admin page
  2. Now enter your router username and password. You can find these on the sticker on the back of your Super Router
  3. Choose Check my Internet Connection Status
  4. Under the Line Quality heading, you'll be able to see your Upstream line rate (upload speed) and your Downstream line rate (download speed)
Message 9 of 14
I also found this log. Perhaps it helps.
Date Type Level Log Content
15:53:02 05/12/2020User LevelNoticeCWMP:Cwmp post inform success.
15:52:37 05/12/2020User LevelNoticeCWMP or STUN parameter be changed.
15:52:33 05/12/2020User LevelNoticeCWMP inform message: acs connection ok.
15:52:33 05/12/2020User LevelNoticeCWMP inform message: event: 6 CONNECTION REQUEST.
15:52:33 05/12/2020User LevelNoticeACS userid make a connection request form 62.24.243.161 to the CPE successful.
15:27:41 05/12/2020User LevelNoticeCWMP:Cwmp post inform success.
15:27:41 05/12/2020User LevelNoticeCWMP or STUN parameter be changed.
15:27:41 05/12/2020User LevelNoticeCWMP inform message: event: 8 DIAGNOSTICS COMPLETE.
15:27:41 05/12/2020User LevelNoticeIPPing diagnosistic is complete.
15:20:31 05/12/2020User LevelNoticeCWMP:Cwmp post inform success.
15:20:31 05/12/2020User LevelNoticeCWMP or STUN parameter be changed.
15:20:31 05/12/2020User LevelNoticeCWMP inform message: event: 8 DIAGNOSTICS COMPLETE.
15:20:31 05/12/2020User LevelNoticeIPPing diagnosistic is complete.
15:18:11 05/12/2020User LevelNoticeUser admin login from 192.168.1.2 successfully.
15:10:21 05/12/2020SecurityWarningDROP FTP Request
15:06:39 05/12/2020WIFINoticeGalaxy-Note9-Wireless 6C:C7:EC:C8:30:75 is disconnected.
15:02:18 05/12/2020WIFINoticeGalaxy-Note9-Wireless 6C:C7:EC:C8:30:75 is connected.
14:27:36 05/12/2020User LevelNoticeUser admin login from 192.168.1.2 successfully.
14:27:22 05/12/2020User LevelWarningUser admin from 192.168.1.2 login failed unlocked.
14:27:06 05/12/2020SecurityWarningDROP TCP SAMBA Request
14:26:22 05/12/2020User LevelNoticeUser admin from 192.168.1.2 login failed. Times of login failure overstep the max value.
14:26:22 05/12/2020User LevelNoticeUser admin login from 192.168.1.2 failed. Password error.
14:25:56 05/12/2020User LevelNoticeUser admin login from 192.168.1.2 failed. Password error.
14:25:54 05/12/2020User LevelNoticeUser admin login from 192.168.1.2 failed. Password error.
14:25:08 05/12/2020User LevelNoticeCWMP:Cwmp post inform success.
14:25:08 05/12/2020User LevelNoticeCWMP or STUN parameter be changed.
00:01:29 01/01/2010User LevelNoticeCWMP or STUN parameter be changed.
00:01:27 01/01/2010User LevelNoticeCWMP inform message: url is changed.
00:01:27 01/01/2010User LevelNoticeCWMP inform message: event: 0 BOOTSTRAP.
00:01:27 01/01/2010User LevelNoticeCWMP inform message: event: 1 BOOT.
00:01:27 01/01/2010User LevelNoticeCWMP inform message: parameter change.
00:01:27 01/01/2010User LevelNoticeCWMP inform message: event: 4 VALUE CHANGE.
00:01:19 01/01/2010SystemNoticeWAN connection INTERNET_TR069_R_VID_101:IPv4 connected.
00:00:46 01/01/2010SystemNoticeDSL connection is active.
00:00:33 01/01/2010SecurityWarningDetect UDP port scan attack, scan packet from 192.168.1.2.
00:00:33 01/01/2010SecurityWarningACCEPT UDP SAMBA Request
00:00:33 01/01/2010SystemNoticeDSL connection is inactive.
18:33:01 03/01/2010SystemWarningReboot: Factory reset by user Reset Button.
18:10:11 03/01/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 connected.
18:10:11 03/01/2010SystemNoticeDSL connection is active.
18:09:51 03/01/2010SystemNoticeDSL connection is inactive.
18:09:35 03/01/2010SystemNoticeDSL connection is inactive.
18:09:19 03/01/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 disconnected.(ERROR_NO_CARRIER)
18:09:19 03/01/2010SystemNoticeDSL connection is inactive.
18:03:57 03/01/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 connected.
18:03:57 03/01/2010SystemNoticeDSL connection is active.
18:03:37 03/01/2010SystemNoticeDSL connection is inactive.
18:03:07 03/01/2010SystemNoticeDSL connection is inactive.
18:02:43 03/01/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 disconnected.(ERROR_NO_CARRIER)
18:02:43 03/01/2010SystemNoticeDSL connection is inactive.
17:59:26 03/01/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 connected.
17:59:26 03/01/2010SystemNoticeDSL connection is active.
17:59:05 03/01/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 disconnected.(ERROR_NO_CARRIER)
17:59:05 03/01/2010SystemNoticeDSL connection is inactive.
17:48:40 03/01/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 connected.
17:48:40 03/01/2010SystemNoticeDSL connection is active.
17:48:19 03/01/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 disconnected.(ERROR_NO_CARRIER)
17:48:19 03/01/2010SystemNoticeDSL connection is inactive.
05:32:02 02/01/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 connected.
05:32:01 02/01/2010SystemNoticeDSL connection is active.
05:31:27 02/01/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 disconnected.(ERROR_NO_CARRIER)
05:31:26 02/01/2010SystemNoticeDSL connection is inactive.
20:08:50 01/01/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 connected.
20:08:49 01/01/2010SystemNoticeDSL connection is active.
20:08:28 01/01/2010SystemNoticeDSL connection is inactive.
20:08:00 01/01/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 disconnected.(ERROR_NO_CARRIER)
20:08:00 01/01/2010SystemNoticeDSL connection is inactive.
18:56:01 01/01/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 connected.
18:56:00 01/01/2010SystemNoticeDSL connection is active.
18:55:37 01/01/2010SystemNoticeDSL connection is inactive.
18:55:25 01/01/2010SystemNoticeDSL connection is inactive.
18:55:02 01/01/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 disconnected.(ERROR_NO_CARRIER)
18:55:02 01/01/2010SystemNoticeDSL connection is inactive.
00:00:43 01/01/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 connected.
00:00:41 01/01/2010SystemNoticeDSL connection is active.
00:00:27 01/01/2010SystemNoticeDSL connection is inactive.
04:23:07 06/03/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 connected.
04:23:06 06/03/2010SystemNoticeDSL connection is active.
04:22:45 06/03/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 disconnected.(ERROR_NO_CARRIER)
04:22:45 06/03/2010SystemNoticeDSL connection is inactive.
14:56:38 05/03/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 connected.
14:56:37 05/03/2010SystemNoticeDSL connection is active.
14:56:09 05/03/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 disconnected.(ERROR_NO_CARRIER)
14:56:09 05/03/2010SystemNoticeDSL connection is inactive.
13:15:23 05/03/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 connected.
13:15:22 05/03/2010SystemNoticeDSL connection is active.
13:15:03 05/03/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 disconnected.(ERROR_NO_CARRIER)
13:15:02 05/03/2010SystemNoticeDSL connection is inactive.
01:04:38 05/03/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 connected.
01:04:37 05/03/2010SystemNoticeDSL connection is active.
01:04:12 05/03/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 disconnected.(ERROR_NO_CARRIER)
01:04:12 05/03/2010SystemNoticeDSL connection is inactive.
14:18:06 04/03/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 connected.
14:18:05 04/03/2010SystemNoticeDSL connection is active.
14:17:44 04/03/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 disconnected.(ERROR_NO_CARRIER)
14:17:44 04/03/2010SystemNoticeDSL connection is inactive.
00:00:47 04/03/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 connected.
00:00:46 04/03/2010SystemNoticeDSL connection is active.
00:00:26 04/03/2010SystemNoticeDSL connection is inactive.
00:00:02 04/03/2010SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 disconnected.(ERROR_NO_CARRIER)
Message 10 of 14
Please see the attached. Capture.jpgIs this it?
Message 11 of 14
I cannot remember exactly, but you need to look for a page called DSL Connection Status, perhaps from the Maintain tab?
Message 12 of 14
H Ferguson,
Sorry, can you explain where can I see the "sync speeds" please. Is somewhere in router diagnostics? When I upgraded to Fibre 65 I was told that I will keep my old router and will not receive the WiFi Hub, which did surprise me a bit.
When I am doing the online test on TalkTalk website, I get internet speeds circa 15Mb and service says that it cannot detect my router and that my broadband connection could be improved.
I tried Router Diagnostics in the router settings using the bbc.co.uk and google.co.uk website addresses but router says that it cannot resolve the host name. Am I doing something wrong?
Message 13 of 14
Can you post the sync speeds from the router? Were you not supplied with a new Hub?
