on 24-06-2019 02:16 PM
hI
Can u help?
Software 1.5t
hardware H.101
phone number in profile
Remote management enabled
on 04-07-2019 11:48 AM
Excellent, glad its all working 🙂
on 04-07-2019 11:36 AM
Went live on fibre this morning.
All good
Thanks to all for help
on 26-06-2019 03:10 PM
No Problem, let us know how things are when fibre is in place.
26-06-2019 02:59 PM - edited 26-06-2019 03:03 PM
Hi Debbie
Received router. Very quick delivery. Thank you
The replacement HG633 didn't arrive but instead the DSL3782
I set it up. Did various speed comparison with the HG633.
The DSL3782 drops 1mg download. The most I ever get is 9mg not the 11mg advertised even though I'm not far from the exchange.
Shame the HG633 couldn't update.
I go live July 4 with the basic fibre. I will see what happens then.
Thanks again Debbie
on 25-06-2019 10:19 AM
Hi typoid
Thank you 🙂
on 25-06-2019 09:07 AM
on 25-06-2019 07:44 AM
Hi typoid
Apologies for this.
I've ordered the replacement router, please allow 24-48hrs for this to arrive.
on 24-06-2019 04:25 PM
on 24-06-2019 04:09 PM
Hi typoid
We can send a replacement HG633 or DSL3782 router via the Community. If you contact our Customer Service Team then they can discuss sending a Wifi Hub.
on 24-06-2019 04:02 PM
on 24-06-2019 03:03 PM
Hi typoid
Unfortunately the firmware update keeps failing, apologies for this. I can send a replacement HG633 router, would you like me to arrange this?
on 24-06-2019 02:52 PM
thanks Debbie
Reset ok but unable to update firmware
on 24-06-2019 02:35 PM
Hi typoid
Please can you factory reset your router using the pin hole reset for ten seconds, I can then try and update your router firmware.
on 24-06-2019 02:26 PM
on 24-06-2019 02:25 PM
on 24-06-2019 02:22 PM
Hi @typoid
Firmware update to v2.0t request is made for you.
Like below to appreciate my help . . . Mark as solved Accept as Solution
