on 19-01-2022 11:19 PM - last edited on 20-01-2022 12:18 PM by Gondola
I'm having exactly the same issues on the firmware.
TalkTalk Wi-Fi Hub
version SG4K100130
Will a fix be pushed or will a new router be required?
on 20-01-2022 01:18 PM
There is an issue with V130 in this situation. I will ask the TalkTalk support staff on here to deal with it for you.
However, if you have Windows 10/11 & use the internal Windows VPN client, they were broken in the last Patch Tuesday update. To remedy this you must install the following optional update:-
Windows 10 KB5010793
Windows 11 KB5010795
