I keep losing internet on my laptop all others ok what’s the problem
carol46
Message 3 of 3
Keep losing internet on my laptop all other I pad etc are ok what’s the problem thanks
Message 1 of 3
Hi carol,
How are you getting on?
Skynet_TX
Message 2 of 3
Hi @carol46,
Do you know if your laptop is trying to connect to the 2.4GHz or 5GHz Wi-Fi signal ?, it is possible you may be suffering from Wi-Fi interference on one of the bands, and maybe your laptop is the only device using that band ?
There are a few things you could try to see if it is Wi-Fi interference causing the problems.
Split the SSID's on the router, this will allow you to give the 2.4GHz and 5GHz network bands different names, so your Wi-Fi devices will then see those two networks separately, you can then try connecting to one or the other to see if one gives a more reliable connection than the other. Doing this in itself won’t fix the problem, but it makes it easier to troubleshoot as you can easily see what device is using what band.
Change the channels that your router broadcasts the Wi-Fi signal on, you can use free smartphone Apps like this to see what channels are being used within range of your smartphone, you can then change your router to use channels that are less congested.
The staff here won't be around now until Monday, but they should be able to respond to this post early next week to help.
